Hello ,
I have a pb on my generator driven by a horizontal 5 hp B&S: I melted the connecting rod
I hesitate to tap on it to take out the rotor and the launcher side has the impression that the flywheel is crimped
Who can tell me how to get the villo out
I would like to find the exploded
please
5 hp briggs engine
Re: 5 hp briggs engine
Hello
it is current currency fart a wrist (rod) on these engines
the biele is in duralumin and costs a 10 $ and is easily changed
loosen the flywheel nut flush with the last thread with a bronze is an aid that holds the engine by the flywheel, a hammer on the nut, without twisting the threads, it will come out it's conical with a half key moon
open the crankcase remove the connecting rod examine the bearing on the crankshaft if necessary with a strip of sandpaper 250 a little bit of polishing, clean well with diesel to remove traces of sanding put oil on the bearing and reassemble everything
The connecting rod flies when it turns faster than 3600rpm or when there is a lack of oil, or when the engine has been running in an abnormal angular position (mowers which cut in an embankment, it is necessary to reverse the position so that the oil arrives at the connecting rod, it is grease by bubbling, it is also necessary to change the oil once a year working or not working ..
Colmant wrote:Hello ,
please
Hello André,
merci,
I found the connecting rod on e bay, in Austin texas 19,95 usd + 6 usd port
by us post airmail delivery time 10 days ...
manufacture in taiwan brand Stens: www.stens.com
I could have perhaps found more meadows and - surely expensive but I took the 1 ° found ...
There is an agent 10 km from my house, found later on the Briggs and Stratton site.
for disassembly, unscrew the ball cage from the manual launcher
and a little tug on the steering wheel
on the other side I unscrewed the alternator rotor by tightening it between two tight wooden blocks with a clamp
well I'm going back up, things have to turn out tonight, it's easy
I found a handyman on the net who is a professional mechanic who will send me the exploded view in pdf I must check the timing of the distribution at + - 1 turn
a+
bruno
merci,
a+
bruno
- Similar topics
- Replies
- views
- Last message
- 18 Replies
- 8334 views
Last message by Christophe
View the latest post
06/09/22, 00:50A subject posted in the forum : Innovations, inventions, patents and ideas for sustainable development
- 730 Replies
- 146615 views
Last message by Eric DUPONT
24/11/23, 13:45A subject posted in the forum : Innovations, inventions, patents and ideas for sustainable development
- 13 Replies
- 7743 views
Last message by Janic
20/06/21, 15:14A subject posted in the forum : Innovations, inventions, patents and ideas for sustainable development
- 42 Replies
- 31294 views
Last message by Lilieth78
20/05/18, 15:32A subject posted in the forum : Innovations, inventions, patents and ideas for sustainable development
- 23 Replies
- 22211 views
Last message by Ahmed
27/02/17, 19:56A subject posted in the forum : Innovations, inventions, patents and ideas for sustainable development
Go back to "Innovations, inventions, patents and ideas for sustainable development"
Who is online ?
Users browsing this forum : No registered users and 220 guests
