Hello everyone.
100% eco-friendly, I am about to acquire a small log cabin in the heart of Auvergne, a chalet which is around 15 years old, to make it my home for a very long time. But, there is a flat that scares me and makes me hesitate to complete the purchase ...
On the south facade of the chalet very exposed to the sun and the rain two planks took moisture at their intersection on 10 cm approximately. The angle also. You can stick a knife in it very easily. When you look at one of these two planks from the side you can see a mushroom. Everything else in the chalet is in perfect condition and has been very well maintained.
This defect was seen by a carpenter who advised me to treat the fungus, double the facade, strengthen the concerned angle and protect all the southern angles.
So my question is this: is this problem serious? Do I take risks of deterioration over time? This purchase is a real long-term commitment for me and I do not want to invest if there is a risk. Also thank you in advance for your advice which will influence the signing or not at the end of April of the sales agreement.
By the way, I have another question about insulation. This chalet is made of simple planks, insulated with rock wool and then paneling. Is it sufficient ? After 15 years, isn't rock wool likely to have sagged?
Thank you all.
See you soon.
plank affected by humidity
I just have the front view but we don't see much ... I try to reach it.
https://www.econologie.com/fichiers/partager/222.JPG
Hello
Pushing the tip of a knife easily into a 15-year-old plank should not be possible.
First is it really a fungus that caused the damage
or is it only opportunistic because this part is Too humid.
Looking for a cause of captive moisture or even indirect seepage should be attempted.
You should (if not already done) carry out a sound survey by tapping on the wood (its full is OK)
If indeed there are only these two planks involved, then a repair can be considered.
BUT always ask the question: why in this place?
If the answer is not found ... rebelote in a while
- Misterloxo
- Éconologue good!
- Registration: 10/02/03, 15:28
- x 1
- Similar topics
- Replies
- views
- Last message
- 17 Replies
- 24883 views
Last message by bham
View the latest post
06/01/07, 10:10A subject posted in the forum : Real estate and eco-construction: diagnostics, HQE, HPE, bioclimatism, natural habitat and climatic architecture
- 19 Replies
- 36387 views
Last message by Philippe Schutt
15/04/07, 12:21A subject posted in the forum : Real estate and eco-construction: diagnostics, HQE, HPE, bioclimatism, natural habitat and climatic architecture
- 54 Replies
- 184974 views
Last message by bernardd
10/02/10, 10:39A subject posted in the forum : Real estate and eco-construction: diagnostics, HQE, HPE, bioclimatism, natural habitat and climatic architecture
Who is online ?
Users browsing this forum : No registered users and 125 guests
