it proves that optimism exists ... temerity too ..
A fuel-saving vortex turbulator: WITH
- nikolaj
- I understand econologic
- Registration: 17/08/17, 18:38
- x 14
Re: A fuel-saving vortex turbulator: WITH
Hello everyone, here is a very interesting video on the air cyclones, and the impressive number of cyclones laid, closer to the intake (on a V 6 engine) and the first is at the exit of the air filter, then 1 second at the inlet of the air manifold, then 6 in each chamber inlet, then 1 at the outlet of the exhaust manifold; then 1 before the catalyst, and finally, 1 exhaust output ... well .. in total: 11 poses ...
A mystery only perpetuates when there is refusal to study it (Georges Charpak?)
A AVEC as close to the intake valves, certainly causes a big turbulence, much more powerful than all the others.
This is compatible or not with an improvement of the combustion ....., on the other hand, the stacking of the others WITH in particular in the exhaust, it is anything ... the only effect is to increase the loss of charge and certainly not to improve the operation of the catalyst that needs a less turbulent flow possible.
The only positive effect compared to the exhaust is to make it can be quieter ... and again, how long ....
Reason is the madness of the strongest. The reason for the less strong it is madness.
- nikolaj
- x 14
HelloFlytox wrote:A AVEC as close to the intake valves, certainly causes a big turbulence, much more powerful than all the others.
hello flytox, by the way, i have already experimented in the exhaust line cyclones air, (i left them with success) and now the exhaust outlet is very very clean ... so i really see that these systems are reliable and efficient ...
- Registration: 17/03/14, 23:42
- x 1524
To find out, a test bench must be made which accurately records, under the same conditions, a quantity of fuel consumed and a quantity of energy measured at the end of the shaft in a given time.Flytox wrote:A AVEC as close to the intake valves, certainly causes a big turbulence, much more powerful than all the others.
This is compatible or not with an improvement of combustion.....
Test to do with and without AVEC, and only under these conditions, one could conclude to any benefit.
A priori, it is unlikely to succeed, since the manufacturers have all the lab equipment and skills and have already tested all possible improvements.
for those who have tried, they do not have the zigoto that expresses itself without knowing, putting it near the valves, less important than the shape of the turbulator and for those who have followed the story WITH its debut results, which are mostly positive, depend more on the adopted form than its position, but also on the meaning of the vortex generated. Chambrin, already, reports the importance of this sense having found that some times vortices are in opposition to the natural meaning generated by the pipes of admission. The remedy is simple just return this WITH to reverse the meaning.Flytox wrote:
Sir I know everything about what he does not know and puts his grain of salt incompetence.This is compatible or not with an improvement of the combustion ..... To know it it is necessary to make a test on bench of measurement which counts with precision and under the same conditions, a quantity of consumed fuel and a measured quantity of energy at the end of the tree in a given time.
most bench tests showed little or no results when these products (WITH, GP) were placed anywhere, regardless of how, without taking into account the advice of true experimenters. But, as luck would have it, it worked well out of those bans.Test to do with and without AVEC, and only under these conditions, one could conclude to any benefit.
There is nothing that does not succeed less than what we do not want to see succeed.A priori, it is unlikely to succeed, since the manufacturers have all the lab equipment and skills and have already tested all possible improvements.
People like André (who left the site rather than being confronted by ignorant fools, Christophe and the elders of this site certainly remember), demonstrated the limits and results he had observed in real life, extreme conditions of Canada, on cars, like his plane, rather than in artificial conditions, out of reality.
You are already no one in biology, to which you add the same nullity in mechanics.
"We make science with facts, like making a house with stones: but an accumulation of facts is no more a science than a pile of stones is a house" Henri Poincaré
- nikolaj
- x 14
Hello everyone, let's remain courteous and benevolent to all, whatever our experiences, expectations, or achievements, the "schmilblick" advances ... again and again, towards more savings ... and benefits ...
- nikolaj
- x 14
after...
- x 1524
That's it. No need to disconnectJanic wrote:most bench tests showed little or no results
Janic wrote:
most bench tests have shown little or no results. No need to disconnect
You do like your friend Exmachin. Cut a quote to reduce or change the meaning so remember:
"most bench tests showed little or no results when these products (WITH, GP), were laid anywhere, no matter how without taking into account the advice of true experimenters. But, coincidentally, it worked well out of these benches.
It is true that when a text exceeds 10 lines, you have trouble following too!
- nikolaj
- x 14
Hello everyone...
18-12-2018 preparation of an air cyclone with double blades, aligned and reversed, in stainless steel 1 mm thick, height 85 mm angle 60 ° pitch 35 mm; very very hard to bend and shape ... the next will be aligned but not reversed ... because it would need another vise adapted and large enough ... (with right-hand tightening to the left ...)
- Similar topics
- Replies
- views
- Last message
- 27 Replies
- 35800 views
Last message by nikolaj
View the latest post
08/11/17, 20:38A subject posted in the forum : special motors, patents, fuel consumption reduction
- 16 Replies
- 22064 views
Last message by elephant
20/10/06, 08:35A subject posted in the forum : special motors, patents, fuel consumption reduction
Back to "Special motors, patents, fuel consumption reduction"
Who is online ?
Users browsing this forum : No registered users and 237 guests
