to be chafoin wrote:yes, but large-scale monoculture has also screwed upMoindreffor wrote:we planted pine trees to dry the marshes and it worked
At the time we did not ask the question in its terms there, the question is why we continue now
to be chafoin wrote:It is at the end of the fair that we count the dung.ChristianC wrote:We made the potatoes harvest; 15 m2, 45 kg.
a / - On the "good hay" plot, planted on 10 m2 with approximately 75 plants, the quantity is 33,5 kg, ie 3,3 kg per m2 and 440 grams per plant.
b / - On the "dry hay" plot, planted on 5 m2 with 30 plants, we had 12 kg, or 2,4 kg per m2 and 330 grams per plant.
The yield is low, but the effort was even more!
But I wish we could make comparisons on our site. As Didier says, we want to pick up more! So ? Your stats and observations friends? What improvements to make?
Last harvest of pdt and small approximate calculations, not to know who has the biggest but to know if the soil / the method is good / at least to get a vague idea even.
A little more than 40kg for a little less than 110 feet, on average a little less than 400g / foot.
By quickly looking at the yields posted on the internet, if we are of course far from Charles Dowding, we are also far from the yields traditionally announced ("1kg per plant") or recorded for example here: http://www.potager-et-jardin.fr/rendement-pomme-de-terre/. What to think? My soil is too poor, or serious lack of growth due to lack of water ...?
Some distinctions and personal gardening remarks:
The cultivation on mown grass and under hay gave a much less good yield on average (to 250g / foot) but I found the crop really nice (while to harvest the pdt under the dry clay ... !! )
Cultivation of the buried peat, butt and then mulched late yielded a slightly worse on average (to 380 g / foot)
The cultivation of the pdt slightly buried then covered with a thick layer of hay gave the best yield
Ahmed wrote:I note, for gardening along the border of Douglas fir, that even the southern areas are infertile, probably due to the removal of water and mineral resources from the peripheral roots.
Did67 wrote:Ahmed wrote:I note, for gardening along the border of Douglas fir, that even the southern areas are infertile, probably due to the removal of water and mineral resources from the peripheral roots.
I made a similar observation, in the "shade" of a plum tree. Poor vegetables. It is not the shadow because it "moves" and does not stay too long.
My conviction is that plum mycorrhizae, well established before vegetables, are much more effective than those of vegetables. So it is this "underground guerilla" which explains, in this case, the misfortunes of vegetables.
We can always "dream" of agroforestry: if we are not termites, we risk starving!
See also, to understand, photos of "burned" under truffle oaks!
https://www.truffiere.org/brule.html
http://www.truffe-passion.fr/spip.php?article63
https://www.planfor.fr/jardin-conseils, ... fiere.html
nico239 wrote:Little evening reflection
The more I consult the net looking for information on vegetables the more I find that it is empty ...
I mean that there are little superficial info of 15 or 20 lines there but few complete protocols (even if we don't want to follow them in full).
Except .... in publications intended for professionals, generally pdf ... and which, they, devote SEVERAL PAGES to each vegetable.
Basically if you're not a pro you have to settle for crumbs or common info.
In short all this to say that there seems to be a real lack in this area for individuals ... like us.
nico239 wrote:Did67 wrote:No, I think "optimize" the green manure AND the non-work:
I am that closely
A question of a different order ... as it seems that this year we will finally be able to prepare correctly the 2019 season so we will do some seedlings indoors.
So the laziest technique is which?
I thought about wood fiber buckets
Or is there better?
Or is it useless?
Or is it to proscribe?
Or ... etc
nico239 wrote:If you find me vegetable themes I am taker ... for the moment I only find pdf of technical sheets or chambers of agriculture ...
In short not very seller / digestible or very general public ... but of course interesting.
My surprise comes from the fact that I thought I was going to collapse under the docs ...
Back to "Agriculture: problems and pollution, new techniques and solutions"
Users browsing this forum : Google [Bot] and 342 guests
