Castor oil based:
"We knew from current knowledge in chemistry that adding water to diesel would allow more efficient combustion. But there was no technology to do this," says Professor Kazuo Tajima. Water and diesel are two substances that usually do not mix. Unless an emulsifier (an agent that combines the two substances), the surfactants, allows water and petroleum to come together. But since these agents can be harmful, the team based at the University of Kanagawa replaced them with castor oil, vegetable oil from a plant called Ricinus Comunis and cultivated mainly in India and Brazil ... "
The continuation here:
http://www.japanbar.net/index.php?rub=c ... &ficheN=46
New water / oil emulsion
A doubt assails me.
This transformed castor tree could pollute seriously and in the long term!
Indeed, when there is pollution of hydrocarbons, the light product floats on the water, and the heavy one amalgamates and sinks. On polluted beaches, it collects with a shovel.
Whether a can of magic castor falls into the water or onto the ground, then the water table, the water reached will be inclined to mix intimately, with all the hydrocarbon crap that would pass through it ...
The poison would be diluted, slowly, gently, without evidence, but, after decades, the concentrations would worsen, and the water, source of life of the planet, would be irremediably unsuitable?
Castor oil has long been used in competition (before the arrival of synthetic oils?) When I was a kid, I mixed it with ether and a little nitromethane to make fuel for micro-engines. self-ignition (no longer used because it vibrates a lot) of model aircraft.
It is also used as a purgative.
I have never heard of pollution from this oil. Insofar as a derivative of this product makes hydrocarbons miscible with water, this obviously requires precautions. Are there not microorganisms that biograde hydrocarbons even when mixed with water?
Personally I was considering making a castor alcohol emulsion for my diesel because I found a patent on it.
25% ethanol could be incorporated into the castor oil without risk of phase shift.
however it seems to me that castor oil causes problems with the scrubbing of the segments if I have a good memory ...
Hello,
For me you did not regret the price of castor oil, for an experience but to spend a 50 liters ...
Yes, castor oil erases the segments as do vegetable oils, if you use them as a lubricant, but if you use them as fuel in an engine, hot, injector in good condition, this does not pose a problem, (I I added (Klotz) in my vegetable peanut oil a very small amount that completely modifies the smell of the exhaust)
- Similar topics
- Replies
- views
- Last message
- 96 Replies
- 24610 views
Last message by sicetaitsimple
View the latest post
24/12/23, 16:32A subject posted in the forum : Biofuels, biofuels, biofuels, BtL, non-fossil alternative fuels ...
- 2 Replies
- 3291 views
Last message by gaston13
23/07/09, 21:20A subject posted in the forum : Biofuels, biofuels, biofuels, BtL, non-fossil alternative fuels ...
- 0 Replies
- 3239 views
Last message by tinger2048
04/05/09, 18:06A subject posted in the forum : Biofuels, biofuels, biofuels, BtL, non-fossil alternative fuels ...
- 3 Replies
- 4437 views
Last message by Bibiphoque
29/09/08, 10:20A subject posted in the forum : Biofuels, biofuels, biofuels, BtL, non-fossil alternative fuels ...
- 0 Replies
- 2640 views
Last message by jean63
12/03/07, 09:29A subject posted in the forum : Biofuels, biofuels, biofuels, BtL, non-fossil alternative fuels ...
Back to "biofuels, biofuels, biofuels, BtL, non-fossil alternative fuels ..."
Who is online ?
Users browsing this forum : No registered users and 186 guests
