New 4 stroke engine (in English)
Re: New 4 stroke engine
fun, but unbalanced, you should try to compensate the forces of inertia with different pistons in other motions.
- inventor
- I posted 500 messages!
- Registration: 02/03/05, 11:51
- x 82
Remundo wrote:fun, but unbalanced, you should try to compensate the forces of inertia with different pistons in other motions.
probably like here ...
Only one part of the multi-cylinder H engine can be seen on my animation. As you can see the history, it can be 24 cylinders .. the order of ignition can be seen in wikipedia .. If we properly think, the customs of the main cylinder system of Felix Roller, may not have ANY ONE SCREW to twisting ..: wave:
https://en.wikipedia.org/wiki/H_engine
Formal 1 too:
https://en.wikipedia...h_Racing_Motors
https://rafaelschelb.../11/23/60s-h16/
https://en.wikipedia...Lycoming_H-2470
https://en.wikipedia.../Fairey_Monarch
https://en.wikipedia...Whitney_XH-3130
Andrew
Andrew Feliks
- inventor
- x 82
Greg Locock, on 20 Jul 2018 - 09: 49, said:
So where does the sliding motion take place? The oscillating arm is moving length as the pistons move.
These brown elements can be made of Teflon with bronze or graphite. They have relatively large surface cooperation, so the pressures will not be wide .. so they can be done this way ..
Andrew
Andrew
Andrew Feliks
- inventor
- x 82
Formal 1 too:
https://en.wikipedia.org/wiki/British_Racing_Motors
https://rafaelschelb.wordpress.com/2011/11/23/60s-h16/
https://en.wikipedia.org/wiki/Lycoming_H-2470
https://en.wikipedia.org/wiki/Fairey_Monarch
https://en.wikipedia.org/wiki/Pratt_%26_Whitney_XH-3130
https://en.wikipedia.org/wiki/Rolls-Royce_Eagle_(1944)
https://en.wikipedia.org/wiki/Napier_Sabre
Formal 1 too:
Andrew Feliks
- inventor
- x 82
Yes, the "Monitor" Memorial Museum is in New York. I am writing that a steam fire pump invented and built by John Ericsson has saved London before burning ...
So inventor John Ericson contributed to the good history of England.
And my engine Feliks -Commer is a bit like that of a hand-operated fire pump ...
http://greenpointmonitormuseum.org/trav ... index2.htm
Andrew
Andrew
Andrew Feliks
- inventor
- x 82
We'll be back in time, for the first project ...
Here with a sketched diagram in cylinders. the standard standard normed by the timing.
You can see a huge difference in volume and its asymmetry ..
Adding well-done gasodynamic phenomena, the volume of one cylinder can even be 700 ccm of really sucked air, with a basic piston of 300 ccm.
Well, it's a little not surprising to receive this 200 hp at 5000 rpm with 1 liter of basic capacity ..
But I do not know for you ... I can not wait for you ... I can know ...
Andrew
Andrew
Andrew Feliks
- inventor
- x 82
Here is the thermodynamic problem .. We have in a box, in a vacuum is a set of thermal engines with generators ... Will this set be more efficient than it would be normally installed without a box?
it's about how laws of thermodynamics work on the Equator, and how on the Pole.
Different temperatures
on the Equator 40 degrees Celsius and at the Pole - 40 degrees Celsius also for efficiency and the layout of the engine will be important ...?
Andrew
Andrew
Andrew Feliks
- inventor
- x 82
Unfortunately, the Carnot engine is only a fragment of the reality surrounding us related to heat engines .. But most try to explain it as a generally applicable law. In the meantime, for example, you can do a simple experiment at home with a "cold engine". Just pour cold water into the sink and put a screwed plastic drink bottle into it. We will see how it will change its shape due to the cooling of the air inside by cold water. Based on the change in its appearance, we see that also the engine would be possible on this principle. Everything is relative in physics .. But learning about heat omits many important physical quantities such as evaporation, freezing and most important - time. And theoreticians come to the conclusion that entropy is steadily increasing, but what about the scientific approach cannot be reconciled too much, because what will happen if this entropy is ever going to run out? ;)
I present here, probably the largest heat engine that a man can build (It is suitable for the Guinness book of records;)) And theoretically, the pressure does not play any role in it, because the balloon from below is open .. the air heats up and the balloon can rise even at 5000 meters (record is 20,000 m), then the first balloon empties from warm air and fills the second, which thanks to the scrolling line to their tether will do electricity in the generator. Then the cycle repeats, from what we release at the top warm air and the bottom one, we fill it ... The old good principle and pressure does not play any role .. It's just a curiosity that not everything with heat is a Carnot engine ..
By the way, a hot air balloon is the longest-lasting machine in the air so far - the record is over 10 days...
This shows because maybe there are other heat engines with higher efficiency than currently known. Anyway. there is already a contribution to new thinking ...
Andrew
Andrew
Andrew Feliks
- inventor
- x 82
So here in slow motion you can see how the valve works in a four-stroke internal combustion engine .. You can see perfectly the "precision" of this mechanism .. It is best to watch it on the maximum screen .. You can see how the valve is when not pressed (and then there is a stroke of work with high pressure) we are simply shaken by the effect of spring vibrations bouncing off the valve face and inertia .. At the bottom of this valve there is a "mushroom "which closes the way to the cylinder .. But since the valve stem dances so, the mushroom also makes such movements .. A since it performs these movements, even when it is" theoretically "closed, it really does not close the cylinder tightly , despite the fact that it is subject to a stroke pressure of up to 100 atmospheres. And we can imagine how much of this pressure escapes from the cylinder, on the effect of these "supposed" small, but very spoiling cylinder tightness, the movements of this mushroom .. Because at a pressure of 100 atmospheres, we can imagine that even a small gap, however, can even drop to 30 atmospheres make .. this mechanism is economical, and produced in virtually all internal combustion engines .. And complacency that the valve will be tight, because it presses it to the seat, high pressure in the cylinder is only the "wishful thinking" of the designers of such a system. because you can see that this is not true, because the valve sways and bounces off the socket, just when it should be closed ... This film helped me understand why my engine without these valves has such high efficiency and power, because how it receives in the cylinder, these 100 atmospheres, I will never lose my tightness all the time, closing the "valve", maybe like 2 atmospheres .. Well, but the amount of energy to use will be 3 times greater than in a traditional engine ... because 98 atmospheres .. And so on every cylinder .. adding to this even 40% more displacement, and twice as high achievable maximum revolutions, it also receives incredible power ten times greater than the original factory engine ... the load . Well, to find out about all this, I had to do [for 3 years of hard work a prototype of this engine, and say that it is so, although at first it did not seem to me at all, that so much is possible .. But it is thanks theoretically, to drive a Toddler (Fiat 126), with the same power as the original, you need a motor that will be smaller these ... 10 times .. But all this can not be determined by just watching the animations of my engine and criticizing me .. You need to spend your private million dollars to find out that this is the case ... And this film also shows that it is possible with all the imperfections of the current valve system .. .
Even an indicator pressure test on an oscilloscope shows us that the pressure drops, but does not show us WHERE it escapes ...
Andrew
Andrew
Andrew Feliks
Back to "Econology forum in english »
Who is online ?
Users browsing this forum : No registered users and 68 guests
