Twice in a row, the dishes came out dirty and the smell of heated plastic was felt.
It is an OCEANIC LVW1249DD of 7 years.
So I performed a test run on the quick program, connected with a consumption meter.
The cycle begins with emptying> the pump operates.
Then filling> No solenoid valve problem.
Then start the wash. Normally a clack is heard then we hear the water circulate and the arms rotate.
Instead, a purring that lasts a moment, a consumption of 270 w and that smell of burning that comes back.
Then the machine finally starts and turns apparently normally (About 80 w, then 1500w for heating the water).
I stopped the machine and restarted while the water is empty.
Diagnosis: Probably the faulty capacitor or bad contact.
While searching on the internet, I came across this: https://www.commentreparer.com/34642/La ... marre-plus
Pile-hair my problem.
And this explanatory video:
The capacitor is an 3 μF and I just kept an old engine with an 4 μF.
Normally it is not critical, I will try to replace only the condo, because to dismount it always goes.
Bingo it reworked the first shots
