Le Potager du Sloth: Gardening without fatigue more than Bio
Agriculture and soil. Pollution control, soil remediation, humus and new agricultural techniques.
Moindreffor
Registration: 27/05/17, 22:20
x 957
Re: The Kitchen Garden Sloth: Gardening without fatigue more than Bio
by Moindreffor » 22/06/18, 22:03
nico239 wrote:
Moindreffor wrote:Horror, my beans froze !!!
I sowed beans, and I transplanted them two days ago, today the landscaper came to mow, so I go to the garden to spread the mowing, and there, what do I see, some bean plants that have all the signs of frost, and this morning there was only 6.8 ° C to 7h, so it went down a bit more and the hay did not heat up enough on the surface, my beans did the cool : Cry:
Gosh ....
At that time?
Sorry for you...
Yeah I've hallucinated this after all the signs, but is it something else, would anyone have an idea?
"Those with the biggest ears are not the ones who hear the best"
(of me)
User avatar
Adrien (ex-nico239)
Registration: 31/05/17, 15:43
x 2150
by Adrien (ex-nico239) » 22/06/18, 22:12
Did you check the weather temperature for the night?
Moindreffor
x 957
by Moindreffor » 22/06/18, 22:16
nico239 wrote:Did you check the weather temperature for the night?
night with clear sky, so rapid dissipation of accumulated heat, it may not have frozen, but the beans are considered very fragile with respect to the cold, so cool enough that they take a hit on the nipple
(of me)
User avatar
Adrien (ex-nico239)
x 2150
by Adrien (ex-nico239) » 22/06/18, 22:21
Do you know if they can leave?
fl78960
I understand econologic
Registration: 16/02/18, 13:19
x 24
by fl78960 » 23/06/18, 09:36
Did67 wrote:I will annotate it. As you will locate the different points mentioned in the videos.
try google earth, the image quality is better (at least for the aerial images of my house).
phil53
Registration: 25/04/08, 10:26
x 202
by phil53 » 23/06/18, 10:53
the leaves are flaccid and soft rather dark green or dried and rather clear?
Mine took a sunburn after the cloudy days and suddenly super hot. This is the second case for mine.
User avatar
Moderator
Moderator
Registration: 20/01/08, 16:34
x 8685
by Did67 » 23/06/18, 11:53
Would not it be rather a bacterial desiccation ???
http://driaaf.ile-de-france.agriculture ... 8332e2.pdf
The "quasi-tropical" period that we have known is very favorable to this kind of accident ...
Moindreffor
x 957
by Moindreffor » 23/06/18, 16:57
Did67 wrote:Would not it be rather a bacterial desiccation ???
I sowed it beans in buckets, the buckets were outside for several days, in full Sun, I transplanted them the eves, the leaves have the same aspect that after a freeze, black and parched, they were at the stage 2 true leaves so I think 2 or 3 buckets (the smallest of the lines) are screwed, this night the thermometer indicated 4 ° C the probe is along a wall almost to the north that receives some sun , the evening
(of me)
User avatar
guibnd
Éconologue good!
Éconologue good!
Registration: 24/07/17, 14:58
x 68
by guibnd » 24/06/18, 07:52
Did67 wrote:
Guibnd wrote:
do some of you have onions that go up to seed? mine (my red onions) transplanted in the spring are rising and suddenly no pretty bulbs on the foot and a stem in hollow tube. not terrible !
already last year, I had some like that but this year is the 3 / 4!
It's been two years since my "reds" gave me the shot ... One year, it was I believe "Brunswick Reds", and the other "Carmen" ... It seems to be a choice of red ...
- perhaps they can not manage the excess of fertility and decree, once the nitrification of the hay committed, that they will manage to do their cycle in one year instead of two - it makes a year of gained? ???
- Gerbeaud says this: "a premature drop in temperatures over a number of days, especially in biennials which need a long period of cold to trigger the reproductive phase. This particularly concerns carrot, celery and onion." Maybe this is still an exception and should it be planted much later ??? Test to be planned next year.
https://www.gerbeaud.com/jardin/fiches/ ... raines.php
Note, the traditional countries of red onions tend to be "mild winter": Roscoff, Lanzarote, Florence ... In Africa, "Galmi violet" is cultivated. Onions from Dogon country are purple ...
In the meantime, there is only one solution: harvest as soon as the flower head forms, to "save what can be saved" (the bulb already formed; otherwise, its contents will be transferred to the stems and seeds!)
It's done, the 3 / 4 of my seed-mounted red onions are torn off, it will be the first eaten!
Red onions is more than it was at home! Before it was a very easy crop, since 3-4 years they abort (I mean by that: do not grow), go to seed prematurely (with or without hay)
What month would it be necessary to sow N1 red onions for transplanting in the spring of N + 2? (To make one's own plant)
Twandering with clayey and fertile wheat, full of water in winter, cold in spring, crushed and cracked in summer,
but that was before the Didite ...
User avatar
guibnd
Éconologue good!
Éconologue good!
x 68
by guibnd » 24/06/18, 08:01
I too had a night at 6 degrees on the night of Thursday 21 to Friday 22 June, no particular signs on the bean leaves nor on the other vegetables at the moment.
But I find some vegetables a little bumpy this year, including beans, zucchini, potimarrons, sweet potatoes, all cabbages, celery raves, even potatoes
The harvest of peas has been (and still is) at the height of flowering. And you, Nico, where are your peas?
  • Similar topics
    Replies
    views
    Last message
Back to "Agriculture: problems and pollution, new techniques and solutions"
Who is online ?
Users browsing this forum : No registered users and 270 guests
