Hello everyone, here are recent installations on a kangoo (1998 td) and 4 space (2 l td 2007)
Installations a tank of rainwater bubbler (0.5 liter of water), (without reactor-heater on the exhaust tube), and a cyclone air into the air intake tube.
already, the owner of the kangoo declares that his vehicle has more fishing ... after a week ...
Ditto for me: 30-05-2018 mounting of the bubbler (0.5 liter of water) and a cyclone air in the air intake tube on my 4 space td 2l of 2007 ... average consumption (calculator table before assembly: 6.4 liters of go to 100 km
I will then publish the observed consumption ...
2017 NIKOLAJ STEAM GENERATOR
- nikolaj
- I understand econologic
- Registration: 17/08/17, 18:38
- x 14
Re: 2017 NIKOLAJ STEAM GENERATOR
A mystery only perpetuates when there is refusal to study it (Georges Charpak?)
- nikolaj
- x 14
Following photos for the kangoo ...
Good evening Nikolaj,
In the photo of Kangoo I understand that a spoon is mounted upstream of the air filter to push the air to the bubbler and the spoon-diffuser downstream sucks the misty water from the bubbler to the engine?
Cdlt
Cdlt
- nikolaj
- x 14
Gildas wrote:Good evening Nikolaj,
Cdlt
Hello to you, yes indeed, a tube of 10 mm diameter and 40 mm about long, with three oblong holes of maximum length let air to the mini bubbler (0.5 liter capacity) ... and it works perfectly without a heating reactor ...
well to you, cordially ...
here are some pictures of the types of diffusers (vacuums too) with oblong holes ...
- Attachments
- 5.jpg (5.06 KB) Viewed times 5676
- 4.jpg (4.33 KB) Viewed times 5676
- 3.jpg (25.76 KB) Viewed times 5676
- 2.jpg (6.58 KB) Viewed times 5676
- 1.jpg (7.04 KB) Viewed times 5676
Nikolaj,
Could you give us a little sketch of your achievements on Kangoo and space?
We look forward to seeing you!
Michel
Michel
- nikolaj
- x 14
Mike12721 wrote:Nikolaj,
Michel
hello, ok as soon as possible ...
- nikolaj
- x 14
hello, here is the last 6 60 20 60 86 60 72 XNUMX XNUMX XNUMX mm XNUMX for XNUMX air hose diameter expandable
Galvanized steel 4 / 10ème mm
4 2ltd distribution chain space (2007) in addition to the previous assembly (above) of direct vapor aspirators without reactor ...
- Attachments
- 8.PNG (436.84 KIO) Accessed 5634 times
- 7.PNG (389.76 KIO) Accessed 5634 times
- 6.PNG (437.65 KIO) Accessed 5634 times
- 5.PNG (525.36 KIO) Accessed 5634 times
- 4.PNG (886.7 KIO) Accessed 5634 times
- 3.PNG (846.53 KIO) Accessed 5634 times
- 2.PNG (636.42 KIO) Accessed 5634 times
- 1.PNG (302.6 KIO) Accessed 5634 times
- nikolaj
- x 14
continued with index ... Cyclone air 6 blades with 60 ° 20x60 pitch mm 86 mm for extensible air hose diameter from 60 to 72 mm
4 2ltd Distribution String Space (2007)
- Registration: 17/03/14, 23:42
- x 1531
217 km is short to evaluate average consumption. To have a significant survey, it would be necessary to make the comparison with or without system on several full and with the same type of trip.nikolaj wrote:izentrop wrote:Hello,nikolaj wrote:hello to all .... Friday 26 January 2018 .... Road 4 roads (110) + national and departmental roads, crossing villages ... = 17.48 liters of diesel for a course of 217 km with a motorhome about 3.5 tons 544 B 1998 Integral Hymer L = 6 meters ..... 17.48 L: 217 km = 8.05 liters to 100 km ... great equipment: water-vapor doping, and air cyclones do wonders .. .Who's next ?
There are so many variable parameters on the road, that this kind of test could only be significant on a double-blind measurement bench, with or without a modification kit.
hello to you, by the fact that I found, in the real world, no need for a test on a test bench, because such banks seem to have limited parameters, (except the European test ecopra 2018) ECOPRA TEST EUROPEAN ARTÉMIS © 2018
while in the real world, I fill up with diesel fuel, then at the next full, measured miles traveled.
divide the number of liters of diesel by the number of actual km, and multiply by 100 equal the true consumption, the true bench tried in its normal conditions of circulation, especially with a camper of 3.5 tons ...
cordially.
At each fill with my Ford fusion, I do this calculation and it always falls to 5% near to the same extent knowing that I mainly travel in departmental roads and very little city, in a relatively flat area. It changes a lot on other highway-type journeys.
- nikolaj
- x 14
Could you give us a little sketch of your achievements on Kangoo and space? Thank you, Michel
hello to you, here are details and some videos about it ....
https://www.facebook.com/pg/palahniuk.n ... e_internal
cordially...
- Similar topics
- Replies
- views
- Last message
- 1 Replies
- 24628 views
Last message by Christophe
View the latest post
19/03/12, 11:55A subject posted in the forum : Water injection in engines: montages and experiments
- 7 Replies
- 18529 views
Last message by Woodcutter
23/03/09, 17:04A subject posted in the forum : Water injection in engines: montages and experiments
- 5 Replies
- 5266 views
Last message by rodibruno
11/04/08, 04:26A subject posted in the forum : Water injection in engines: montages and experiments
- 137 Replies
- 186188 views
Last message by Neofreespirit
11/11/10, 12:50A subject posted in the forum : Water injection in engines: montages and experiments
- 7 Replies
- 7515 views
Last message by Guest
01/01/70, 01:00A subject posted in the forum : Water injection in engines: montages and experiments
Back to "Water injection in the engines: the assembly and experimentation"
Who is online ?
Users browsing this forum : No registered users and 81 guests
