Ideal heating ...
- Registration: 17/03/14, 23:42
- x 1502
Re: Ideal heating ...
A duplicate is easily erased. All you have to do is re-edit your last message and check "Delete this message permanently (it cannot be restored)" in the options in the editor.
With regard to oil-fired condensing boilers, the tax credit has been reduced to 15% and there are only 2 or 3 eligible models remaining, the price of which is no longer competitive with the Pac (according to a commercial) .
subsidiary question;
I still hesitate between heating my extension autonomously (heat pump or pellet stove) or connect it to the existing heating network of my home (condensing gas). If I opt for the first solution, could I benefit from the different aids?
To read ...
To read ...
do you know him forum ?
http://www.forumveranda.fr/
you may have more information on the administrative side?
it is a subject on which I begin to document
- chatelot16
- Registration: 11/11/07, 17:33
- x 264
you forget to specify the dimension of the existing house ... if it is big enough there is a good chance that the existing boiler is sufficient to heat the 60m2 in addition
this extension is glued to the house so it makes a certain wall surface that will have no heat loss since heated also on the other side
the power to heat a house does not depend exactly on the living space, but also on the wall surface, so that the power increases less than the floor area
chatelot16 wrote:you forget to specify the dimension of the existing house ... if it is big enough there is a good chance that the existing boiler is sufficient to heat the 60m2 in addition
yes of course my boiler is sized to heat the extension is another possibility. But here, that was my question: is it better to treat the extension completely independently or to integrate it? Knowing once again that the building, it will be completely autonomous: I will have two very distinct buildings in the end. Precisely, the help aspect of the state can help in the choice ... I have to study the link that Thibr gave me.
To read ...
- Similar topics
- Replies
- views
- Last message
- 3 Replies
- 929 views
Last message by Lanig22
View the latest post
10/03/24, 18:51A subject posted in the forum : Heating, insulation, ventilation, VMC, cooling ...
- 8 Replies
- 1761 views
Last message by Ahmed
16/02/23, 11:19A subject posted in the forum : Heating, insulation, ventilation, VMC, cooling ...
- 25 Replies
- 5278 views
Last message by Christophe
03/12/22, 10:50A subject posted in the forum : Heating, insulation, ventilation, VMC, cooling ...
- 20 Replies
- 7305 views
Last message by Seb57
22/11/22, 10:19A subject posted in the forum : Heating, insulation, ventilation, VMC, cooling ...
- 4 Replies
- 1829 views
Last message by phil59
26/09/22, 19:31A subject posted in the forum : Heating, insulation, ventilation, VMC, cooling ...
Back to "Heating, insulation, ventilation, VMC, cooling ..."
Who is online ?
Users browsing this forum : No registered users and 310 guests
