Hello everybody
I decided to extend about 60 m² to my home, in the form of an independent building attached to the existing one.
It will be up to current standards (RT2012, VMC) but I'm thinking about how I'm going to heat it.
First question: connect it to existing heating (city gas condensing boiler)? Or treat it independently?
Second question: if I opt for independent heating, what to choose?
My title is obviously provocative but this choice is oh so difficult!
-Electric heating ? Even the storage heaters, a priori economical seems already dice: I heard that the next RT2018 all that is electric heating would be banned ...
- PAC taking calories in the air? In our regions (Auvergne), the winter is cold and the PAC are not very efficient ...
- renewable energies? Wind; excluded in my opinion because the winds are violent where I live; solar? Even if the last generation produces electricity from solar radiation and recovers both the heat and cooling of the panels, in rainy weather, we have neither.
stove (wood, pellets, pellets ...)? Why not, I already have a wood stove for my main home, in addition to the central heating ...
It is true that we are changing with new technologies, passive houses etc ... But I have the impression that we have little perspective on this and, worse, that this technology is too complex and unfortunately poorly controlled. My father has invested a lot of money in a vertical capture system, he only has emm ..., the company has closed etc ... etc ... Sometimes I think that a good old fire of wood, at least we are sure of the result ...
In short, thank you for giving me your opinion.
Ideal heating ...
Re: Ideal heating ...
It seems to me that it lacks important information: the assignment of this extension.
Depending on whether it should be used (so heated) every day, only at night, or only occasionally the answer will probably be very different.
yes, why not give this precision: it will be two pieces of life, so to heat continuously ...
To read ...
To read ...
- chatelot16
- Registration: 11/11/07, 17:33
- x 264
a good old wood fire we are on the result ... and if we cut the wood itself we are sure not to ruin ourselves
heat pump is the best solution if you have a heat pump that works well ... alas it is not mastered by everyone and we see a lot of problem
the problem of heat pumps is that we forbid everyone to do it yourself, and requires to go through professionals some of whom are worse than handyman ... conversely good handyman are better because he take the time to think and learn ... unlike some professionals who do not have the time to think about working enough to pay for their expenses
for me the ideal heating is gasogenic, generator and heat pump ... but it is an ideal that will be available one day ... but not available right now
so with what is available now I would say heat pump for one who does not want to handle firewood, and being careful to choose a competent installer, knowing to choose a good model of heat pump
and for those who can take care of firewood it is the most economical and the most reliable
yes but again, there are no calories in the cold winter air of Auvergne (often -10 ° C), and so in this case, the heating is provided by electrical resistors and there, oull the wallet !!!!
To read ...
To read ...
The wood is ideal ... if there is someone to feed the fire during the day.
Otherwise, we must move towards an automatic system, so a pellet boiler, a gas boiler (since the housing seems already supplied with gas), a heat pump or a convector heater.
Knowing that those which are the most economical to use are the most expensive to install, there is no "ideal" but only a compromise between the wallet and the ecology.
For a piece of 60 m2 in rt2012, the simplest, the least expensive (with the purchase as with the use), it is a pac air-air of big mark, inverter and optimized very cold, about 3 kW. This will be suitable up to temperatures of -15 ° -20 ° C.
Investment below 2000 € (installation included), annual conso less than 100 €; you can do most of the installation, with the only startup by a refrigeration, it will reduce the investment (it's easy to do, and within reach of any average DIYer). Check here: domotelec.fr and selected in the range Mitsubishi (hyper heating) or Hitachi or Panasonic ...
No need to increase the amperage of the meter, it is less powerful than a vacuum cleaner ... No annual maintenance apart from dusting done by you. It is without competition in heating. Little more, it will eventually serve as air conditioning during heatwaves ...
Still need to find a refrigeration company who agrees to come and connect an installation that he did not sell ...bardal wrote:you can do most of the installation, with the only operation by a refrigeration engineer,
It's a good option if you have a friend ...
I am a little more mixed than you with respect to the PAC because we do not have a very good visibility on the service life after the warranty period ... and bad examples of irreparable models after 4 or 5 years.bardal wrote:No annual maintenance apart from dusting done by you. It is without competition in heating.
- chatelot16
- x 264
a -10 ° C there are still calories to pump
it is at 0 ° K = -273 ° C that there is no more calories at all
of course -10 ° C the heat pump cop is worse but still better than a simple electric heater
the heat pump allows to add all the energy sources that it wants including the renewable energy ... contrirement with the oil or the gas which appears to me a misuse of fuel which should be reserved for uses more noble than heating
https://fr.wikipedia.org/wiki/Cycle_de_Carnot
cop for -10 ° C = 263 ° K outside and 30 ° C = 303 ° K inside:
cop = 1 / (1-Tf / Tc) = 1 / (1-263 / 303) = 7,57
I took an example where the heating is done by a floor heating which allows to use a low temperature ... the cop decreases with a radiator which needs a stronger temperature
alas the current heat pump we have a cop much lower than the theoretical maximum ... there is still progress to be made
Yes, but we are starting to encounter some basic technical problems such as the frost accumulating on the external exchanger.chatelot16 wrote:a -10 ° C there are still calories to pump
- Similar topics
- Replies
- views
- Last message
- 3 Replies
- 1081 views
Last message by Lanig22
View the latest post
10/03/24, 18:51A subject posted in the forum : Heating, insulation, ventilation, VMC, cooling ...
- 8 Replies
- 1884 views
Last message by Ahmed
16/02/23, 11:19A subject posted in the forum : Heating, insulation, ventilation, VMC, cooling ...
- 25 Replies
- 5475 views
Last message by Christophe
03/12/22, 10:50A subject posted in the forum : Heating, insulation, ventilation, VMC, cooling ...
- 20 Replies
- 7547 views
Last message by Seb57
22/11/22, 10:19A subject posted in the forum : Heating, insulation, ventilation, VMC, cooling ...
- 4 Replies
- 1869 views
Last message by phil59
26/09/22, 19:31A subject posted in the forum : Heating, insulation, ventilation, VMC, cooling ...
Back to "Heating, insulation, ventilation, VMC, cooling ..."
Who is online ?
Users browsing this forum : Google Adsense [Bot] and 320 guests
