hello to all, news on this forum, I would like to have feedback on the lazy method when you have to "feed" a clay soil which is therefore easily compact. I live in the Charolais with land that can fatten (according to the stories of old farmers) a Charolais cow per hectare, so it's not for nothing that I think I have gold in my garden. But even if she is very generous in summer, she is super in love in winters, and compacts at the slightest annoyance. I do not manage to have these lumps so glorified despite various coverings, inputs of manure and leaves, a little green manure and for the moment a little grelinette to try to decompact a minimum.
thank you for sharing your experiences
Clay ground
- I understand econologic
- Registration: 09/12/17, 17:55
- x 11
Re: clay earth
Hello,
I also have a clay soil.
if you go down to ~ 25cm I have good pottery ground, well yellow orange ...
it's been a few years (I do not know exactly 4-5 at least) that I cover with hay and occasionally with horse manure.
the land begins to improve slowly (I'm doing grelinette this year and use only fangs to loosen it).
Regarding the manure, I advise you that of cow for the clay lands. For the rest I could not find anything better than waiting and covering with hay
Re: clay earth
I also have clay soil, and for lumps, forget for now, it will have to come with time
Denis
PS this is my second year in fenoculture and for the moment nothing happens (I mean that there is a priori no visible soil aggradation), but this does not prevent the vegetables from push.
Denis
Denis
Denis
- to be chafoin
- Grand Econologue
- Registration: 20/05/18, 23:11
- x 97
Re: Clay Earth
I have the same type of soil ... and problem.
I came to wonder if we should not do with it. Didier seems to think that the plants can adapt to this soil and go get what they need and that basically it is a prerogative to believe that a plant absolutely needs a loose soil. Perhaps this apriori is due to our conception (outdated) of a good culture (tillage ...)?
It is true that it is difficult to leave: I often have the impression after the establishment, that the rooting is a very difficult and long phase. It takes time before the plant really rises to the heights (if indeed the two things are related, but hey ..). But perhaps it is due to my technique of culture, because sometimes I have plants that can very well take root. For example, these soils are cold and slow to warm up more than the others in the spring so maybe my impression is due to a too early planting period compared to the soil? This year I decided to retain 1, 2 even 3 weeks more. Moreover I find that with the heat, the ground closes and becomes hard like concrete. So I try to cover my soil more systematically and with a thicker and more extensive cover of hay to limit the cracks (see picture on my thread: a meadow?). We'll see...
But what do you think is difficult with these soils? Is this also the start-up period?
Re: Clay Earth
Hello
try to spend a crotch fork in the future furrow to sow. One passage a day, without trying to penetrate deeply. This requires almost no effort, does not disrupt the layers, and without seeming to, at a rate of one cm per day the soil will be loosened on 15cm 15 days and especially not hardened whatever the temperature. Cover the ground, after semi, obviously!
Needless to say, this work must begin after a rain and its drying for a day or two, before hardening. (but I specify it anyway!)
"We make science with facts, like making a house with stones: but an accumulation of facts is no more a science than a pile of stones is a house" Henri Poincaré
Re: Clay Earth
to be chafoin wrote:J
Yes...
the start of some vegetables often seems long and less rapid progress than eg the vegetable garden of the neighbor, carefully motocultured and milled ... but then, in summer and autumn, it works well!
for seedlings (eg peas this year) I also have gaps in the rank often, while the neighbor seems better. But it's not that kind of little details that will discourage me, knowing that for two years my garden produces very well, without (or with very little) tillage.
Re: Clay Earth
actually, at home too the vegetables have a hard time to start and I also think of the ground a little colder but in summer and autumn it's the vegetable festival in the garden.
I asked myself the question to decompact this clay soil; maybe we should focus on the roots. that is to say not to count only on an "inert" cover (although the soil still works), but at the slightest opportunity on a maximum of living plants and that in all seasons, and in addition these plants would also be water pumps in autumn and spring.
on the other hand difficult to manage all this with vegetables, ....
What do you think ?
What do you think ?
Re: Clay Earth
Hello,
There are different types of clays that do not have the same properties. Do you have any ideas of proportion in clay? of their type?
In general, clay soils have a very strong "inertia", in the event of changes in practices, time is needed for a new dynamic equilibrium to appear. So you have to be patient.
A cover that then leads to an enrichment in organic matter is a good thing that can help make the soil a little lighter on the superficial horizon.
One option would be to add a fairly fine organic material and incorporate it in a superficial way before maintaining a hay cover, but this still leads to some tillage.
The cracking due to retraction is not bad in itself, it can even be positive (except for constructions )
On the other hand, it is true that in the case of soaked soils, it is better to stay at home, both for the gardener and for the soil. And indeed, the warming of soils is long and this can even be a little exacerbated by a thick mulch cover.
- to be chafoin
- Grand Econologue
- x 97
Re: Clay Earth
Yes the retraction can have positive sides: I imagine that for example the first rain that falls can penetrate deep quickly (as in earthworm holes?) And suddenly, do not easily undergo evaporation by the following.
But I still believe that retractions are rather negative overall for vegetable crops: tearing networks of mushrooms, or worms galleries or even plant roots ... They also go hand in hand with a closure of the earth that hardens considerably. It then takes a long rainy period for the earth to reopen. If a crop is already in place, it's good, otherwise the plant will have to devote a lot of energy to its root tissue ...
- Similar topics
- Replies
- views
- Last message
- 3 Replies
- 4851 views
Last message by izentrop
View the latest post
19/07/21, 23:37A subject posted in the forum : Agriculture: problems and pollution, new technologies and solutions
- 262 Replies
- 52540 views
Last message by Did67
02/10/21, 11:18A subject posted in the forum : Agriculture: problems and pollution, new technologies and solutions
- 1 Replies
- 3273 views
Last message by Christophe
21/01/21, 09:52A subject posted in the forum : Agriculture: problems and pollution, new technologies and solutions
- 5 Replies
- 7019 views
Last message by Gardenerof54
16/01/22, 12:16A subject posted in the forum : Agriculture: problems and pollution, new technologies and solutions
- 30 Replies
- 12024 views
21/02/24, 14:45A subject posted in the forum : Agriculture: problems and pollution, new technologies and solutions
Back to "Agriculture: problems and pollution, new techniques and solutions"
Who is online ?
Users browsing this forum : No registered users and 393 guests
