chatelot16 wrote:if we burn the grass or grass mixed in good proportion with crushed wood it works very well!
ok but what proportion?
To read ...
chatelot16 wrote:if turf has a c / n ratio of 10 instead of 300 for wood, it's still mainly carbon, so it does not reduce much the calorific value ... it's just that nitrogen increases polution if we burn in a single fireplace and only turf
if you burn in a gasifier with a chemical purification of the gas before burning it became very clean ... a good gas generator can even burn clean pvc!
if we burn the grass or grass mixed in good proportion with crushed wood it works very well! the mixture with wood solves both the problem of drying for good conservation and avoids the problem of pollution by a fuel too rich in nitrogen
Maybe if the grass contains more nitrogen than the hay and it is too much, it is enough to intentionally leave a little wood to make the right mixture and to make "reconstituted hay" with sod and wood.
Back to "biofuels, biofuels, biofuels, BtL, non-fossil alternative fuels ..."
Users browsing this forum : No registered users and 192 guests
