Principle of operation of a 6 cylinder engine with a crosshead, Watt type, Feliks gold cross-line tray. So what gives us ... no friction piston by cylinder, so we can give up the oil for lubrication (oil pumps too), and gives 15% torque increase. Possibility of excellent cooling of the pistons with water, which will increase the compression ratio by 2 units. this is the next 10% .. Well, ecology, no oil burning, and less NOx, because in the chamber lower temperature ..
And the lack of crankshaft, because one crank with the connecting rod is hardly called a shaft ... if the engine has 16 cylinders ..: rolleyes:
http://www.railroadhandcar.com/projects ... family.mp4
Andrew
