Hello, I have a flotec 1500 with a bladder of 24l.
At the beginning the water normally comes out with a pressure of 2b. After 15min the pressure decreases gradually until it drops to zero. At this moment the water stops flowing and the pump goes into standby. 10 min after it goes back on its own. And so on. Thanks for enlightening me because I do not understand anything. Before I had a pome speroni without bladder and everything worked perfectly.
Flotec booster problem
Re: Flotec booster problem
These symptoms are strange. You have to observe all the possible parameters in order to discover the cause. Can you check the water level of the well during pumping?
"Please don't believe what I'm telling you."
Thank you for the answer. Indeed I myself do not understand these symptoms. The water level is good. I do not have concrete proof but with my old pump (without bladder) the water came out with a fairly strong and constant flow.
It would be best to be sure of this first, as the water flow may vary over time.
- Similar topics
- Replies
- views
- Last message
- 29 Replies
- 16917 views
Last message by oli 80
View the latest post
13/06/21, 11:11A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 11 Replies
- 22754 views
Last message by izentrop
09/02/21, 09:50A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 1 Replies
- 8758 views
Last message by thibr
28/07/18, 07:16A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 7 Replies
- 11746 views
Last message by Bardal
08/04/18, 18:07A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 3 Replies
- 13582 views
Last message by Fausty
13/09/15, 14:53A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
Who is online ?
Users browsing this forum : No registered users and 162 guests
