Hello,
I find the diagram still a bit complex.
Why not favor with a drain back a large plastic tank is tank in tank systems in the tank. The problem is likely to be corrosion.
Is your circuit drain back is it at a place on the circuit?
In any case, nice work.
My (large) solar thermal project
- Grand Econologue
- Registration: 10/10/13, 16:30
- x 189
Re: My big solar thermal project
Hello,
The diagrams are only tests, I will make the real plan when it will be finished ...
Actually to simplify I will put a large stainless steel solar water tank, from which I will circulate the heat.
For pumping and siphon circuit, I think it is impossible because on a descent of 12 m. the water will evaporate ... An easy solution is to put a tank in height to reduce the work of the pump, and allow at the same time a descent siphon.
Here is a sketch, with perhaps an automatic trap system at the top to block the water and let the air through.
Another advantage is that there will be less evaporation because the water in the tank, in contact with the air, will not be heated.
Yes, the idea of intermediate storage to avoid 12m is good.
You can expertly close your intermediate tank to prevent it from coming into contact with the air.
In this way you avoid corrosion.
Have you thought of storage in the ground because you will have a surplus in summer?
- I discovered econologic
- Registration: 17/05/18, 15:51
Hello,
The 24v circulator of the 24-26 303 class 5 boiler is not a small circulator but a real circulator with the same performance as the 230 volt, height 6 meters.
Have a good day,
Have a good day,
- Grand Econologue
- x 189
Hello everybody
Voila, it's been 2 weeks that the oil boiler has not started!
Pumps purr, 12 l / min per group of panels, PVs ensure when there is sunshine, as soon as a cloud passes the batteries take over, and the cloud passes charging. The pumps consume 86W each, the good surprise is that once the circuit starts it turns to 0.7 - 0.8 bar.
I added PC power supply fans, because otherwise the engines quickly exceed 100 ° (on the record it is 100 ° maxi). With the fans it stabilizes at 70 - 75 °, whatever the temperature of the water.
Some pictures:
A module 3 cylinders
This one was pierced by rust, I sold it, There is only the central cylinder which is stainless steel, the outer shell is steel. Unfortunately, but I realized too late, welding the steel shrinkage tensions have cracked the stainless steel ... but my welding does not leak!
The interior of a stainless steel cylinder, capacity 112 liters.
The 3 modules of the ecs, that of the center is pierced but is traversed by the primary water ...
The 4 cylinders module which is the solar boiler.
The circulator of the primary.
The connection of the primary to the boiler.
Pumps 24V, the start is not yet automatic because a single pump can not start the circuit, to start I start 3 pumps, about 3 minutes after I cut the pump down and I open the valve .
The electrical panel with a voltmeter for each battery.
Some pictures:
- Grand Econologue
- x 189
Obviously I isolated the modules, live because I started to heat as soon as everything was waterproof
I have to bend all this, and especially to automate the system!
- Grand Econologue
- x 189
Hello
Here is 7 month that it turns, the pumps circulated 1200 m3 water (always the same) in the panels, 825 operating hours (24 l / min on average).
In the meantime, residents have been drawing 124 m3 hot water! About 40% oil and 60% solar (estimate 3700 kWh solar), from November to January it produced very little, in February I could do 20h solar heating in addition to the ecs. to 14h if the ecs is hot, I open the valve and solar heats the boiler (I unplug the burner), it works well live.
Otherwise, the system is automated, I found a pump that can start, and with relays the heat exchanger circulator starts at the same time as the pumps. The delta t ° is set to 20 ° for the start and 2 ° for the stop, at the beginning I had problems of untimely stop at the passage of a cloud, I even tightened a pump because at restart it There was still air and it did not start.
- Philippe Schutt
- Registration: 25/12/05, 18:03
- x 33
At 10kwh per liter of fuel oil, it is already 370 liters won in 1 months.
Chapeau!
Chapeau!
- Grand Econologue
- x 189
In 7 months, not 1 months! (or 4 months if subtracted nov-dec-jan)
Although it still produced a little bit, the days of sunshine. I will try to do the calculation month by month, since I read the meters regularly. I have an hour counter on the charge pump of the final water heater (oil), I refer to the measurements made in summer before the solar, but it is not very accurate because in winter the boiler also heats the radiators while charging the water heater.
- Moderator
- x 10972
Nice building Dede! It is heavy! It reminds me of Tigger's installation: Solar-thermal / solar-installation-the-wood-of-Tigger-with-buffer-thermal t5200.html
How did you recover and at what price the ECS horizontal heat exchangers?
This is industry equipment or hospitals that! In nine it must be severe!
- Similar topics
- Replies
- views
- Last message
- 24 Replies
- 2679 views
Last message by Remundo
View the latest post
30/08/23, 22:48A subject posted in the forum : Solar thermal: solar collectors CESI, heating, hot water, stoves and solar cookers
- 30 Replies
- 18212 views
Last message by Philippe Schutt
27/05/20, 16:42A subject posted in the forum : Solar thermal: solar collectors CESI, heating, hot water, stoves and solar cookers
- 1 Replies
- 5740 views
Last message by oli 80
15/06/17, 21:49A subject posted in the forum : Solar thermal: solar collectors CESI, heating, hot water, stoves and solar cookers
- 1 Replies
- 8843 views
19/01/14, 19:48A subject posted in the forum : Solar thermal: solar collectors CESI, heating, hot water, stoves and solar cookers
- 11 Replies
- 18725 views
Last message by swallowtail
24/11/13, 21:41A subject posted in the forum : Solar thermal: solar collectors CESI, heating, hot water, stoves and solar cookers
Back to "Solar thermal: solar collectors CESI, heating, hot water, stoves and solar cookers"
Who is online ?
Users browsing this forum : No registered users and 117 guests
