Hello,
To change the assignment a dependency that lacked height, without wanting to encroach on the neighbor, we decided to make a flat roof with EPDM seal.
Professional sites and videos on the subject all advise the hot roof. The concern is that the high temperature insulation is very expensive and requires more height than I expected.
Finally, cold roofing requires an air gap that is not so complicated to achieve. http://www.cndb.org/pdf/CNDB/TELECHARGE ... rrasse.pdf
I thought of doing as shown here (cold roof).
On the other hand, why put the vapor barrier on top of the last strain of insulation? I would have rather put it last, as on the walls
Cold roof or hot roof?
- Moderator
- x 10973
Re: Cold roof or hot roof?
Yes it's strange this first small thickness of insulation, then the vapor barrier and then the main insulation ... There must be a reason ... but what ???
I've never been to flat roofs ... they are perpetually annoying sources ... even if it's done well: the EPDM will never hold as long as a conventional roof (slate, tile .. .)
- Registration: 17/03/14, 23:42
- x 1502
The reason I had it elsewhere
The idea is to create between the ceiling and the vapor barrier, a vacuum in which will circulate all the pipes, electric in particular, which in places cross the ceiling. If the vapor barrier were on the ceiling, it would be damaged.
When the 2th insulation placed on the ceiling, it is actually not mandatory in the strict sense. But the fact of having two successive insulators, crossed supports, improves the overall delivery of insulation because each of the two insulators covers the thermal bridges of the other.
The 1 / 3 is the maximum thermal resistance that can be given to the insulation under PV, to avoid condensation.
If we put zero, we are good, provided that the other insulation is sufficient.
It's recent as a process and there are some interesting estimates http://www.epdm.fr/wa_files/duee_de_vie ... e_epdm.pdf and for my case, it will be the next generation who will maintainChristophe wrote:the EPDM will never hold as long as a conventional roof (slate, tile ...)
- x 1502
New process for high performance insulation to prevent condensation in the frame, summer and winter and I will probably adopt hygro +
- x 1502
Hello,
Finally, I chose the solution of my DIY store that seems to correspond to these recommendations: http://www.programmepacte.fr/sites/defa ... 4-07_0.pdf
It consists of an OSB3 floor covered with a bituminous underlay reinforced with a glass veil. it's glued with cold bitumen glue. Since it's not really glue, you need to point at the top and fix the sides. This underlayer also acts as a vapor barrier.
On top of that, I fixed a PIR insulation (designed for high temperatures). Then the EPDM membrane glued with specific glue beads. I have not managed to avoid creases, but hey, it should not be too tense either.
- Similar topics
- Replies
- views
- Last message
- 14 Replies
- 10768 views
Last message by Remundo
View the latest post
09/02/20, 22:34A subject posted in the forum : Real estate and eco-construction: diagnostics, HQE, HPE, bioclimatism, natural habitat and climatic architecture
- 8 Replies
- 7209 views
Last message by eclectron
04/08/19, 06:51A subject posted in the forum : Real estate and eco-construction: diagnostics, HQE, HPE, bioclimatism, natural habitat and climatic architecture
- 5 Replies
- 12832 views
Last message by 66 amber
25/01/10, 19:10A subject posted in the forum : Real estate and eco-construction: diagnostics, HQE, HPE, bioclimatism, natural habitat and climatic architecture
- 5 Replies
- 15739 views
Last message by minguinhirigue
05/08/08, 18:54A subject posted in the forum : Real estate and eco-construction: diagnostics, HQE, HPE, bioclimatism, natural habitat and climatic architecture
Who is online ?
Users browsing this forum : No registered users and 77 guests
