Yes, that's what I said to myself.
Yes there is enough area coming,
And then it worked well for 1 year and a half and nothing has changed in the room in the meantime.
I tested with the garage door open, I checked that the entrance to the fireplace was clear as well as the small holes at the level of the burner plate.
Problem Okofen "smoke vent" boiler
Re: Okofen “smoke vent” boiler problem
This is what makes me think of the fan, which, if it does not rotate well, becomes the main obstacle. Given the configuration of the exchangers in a condensing boiler, without ventilation, this does not work! Unlike a simple wood stove, for which natural draft is enough.
bjr to all I have a 15kw pelletmatic and I end up with a lot of unburnt pellets in the ashtray is this the same problem? mine not being a condensation? thanks for advice and answers
This is probably a problem during ignition ...
This could be the case if the pellets are wetter than expected (less than 10% humidity). In the event of a failed ignition, it starts the "program" again. And it begins by "filling" the plate of the burner so that the pellets are near the igniter; If this happens again, the plate may overflow ...
- Similar topics
- Replies
- views
- Last message
- 13 Replies
- 1663 views
Last message by gfgh64
View the latest post
18/01/24, 01:56A subject posted in the forum : Heating, insulation, ventilation, VMC, cooling ...
- 2 Replies
- 2085 views
Last message by bighorno
15/12/23, 21:55A subject posted in the forum : Heating, insulation, ventilation, VMC, cooling ...
- 0 Replies
- 1366 views
Last message by Bedouin
28/10/23, 22:10A subject posted in the forum : Heating, insulation, ventilation, VMC, cooling ...
- 83 Replies
- 16392 views
Last message by Pilpoill
05/10/23, 17:01A subject posted in the forum : Heating, insulation, ventilation, VMC, cooling ...
- 5 Replies
- 4747 views
Last message by Flytox
27/01/23, 19:39A subject posted in the forum : Heating, insulation, ventilation, VMC, cooling ...
Back to "Heating, insulation, ventilation, VMC, cooling ..."
Who is online ?
Users browsing this forum : No registered users and 301 guests
