We were talking about turbojets, not reciprocating internal combustion engines. From a process point of view (I do not speak of technology), a reactor is much simpler because all functions (admission, compression, combustion, expansion, exhaust) are made in a dedicated section of the machine, continuously. In an alternative engine it is the opposite, everything is done in the same place and successively.
The article cited speaks of engines, not reactors. So do not generalize.
Water injection competing in 80 years
- Registration: 31/10/16, 18:51
- x 2673
Re: Water injection competing in the 80 years
Different water injection can be adapted to a reactor ...
- x 2673
Yes, but only as stated above to increase take-off thrust.
Bolt wrote:Econology wrote:.... 3 distinct essential roles:
- Increase the admission rate, ie the mass of mixture, by cooling the mixture or intake air by evaporation of this water. Thus this increased the specific power of the engine.
it deserves reflection, even if the result was there
that would mean that the part of water injected, gaining volume after having evaporated, even if it is a small quantity (at 1 atm the volume taken by water is multiplied by 1700 approx, here at 2,8 atm, it would be 607)
would be less important than the contraction of intake air that would go from 60 ° C to 12 ° C (14,4% less volume)
Who is stalled in mass heat?
Or the vaporization starts by making small droplets that are only partially evaporated in the intake pipe, and end up cooling the air during compression, vaporizing completely, but here we are already, I think in the second pointEconology wrote:- increase the detonation resistance of the mixture (ie increase the octane number of the mixture). In this sense, this joins the MW50 - Methanol Water - injection on 2e WWII fighter planes (click here for more information).
here is for chemistsEconology wrote:- cool the internal components (including: liner, valve, seat, piston ...) of the engine during strong solicitations. [/ i]
Here is the most understandable
bolt
Yeah, I totally agree with you
- Similar topics
- Replies
- views
- Last message
- 11 Replies
- 33097 views
Last message by Christophe
View the latest post
04/09/16, 19:12A subject posted in the forum : Water injection in heat engines: information and explanations
- 3 Replies
- 9336 views
28/06/16, 23:24A subject posted in the forum : Water injection in heat engines: information and explanations
- 25 Replies
- 23538 views
12/03/16, 03:18A subject posted in the forum : Water injection in heat engines: information and explanations
- 18 Replies
- 21178 views
07/10/17, 18:56A subject posted in the forum : Water injection in heat engines: information and explanations
- 35 Replies
- 53634 views
Last message by Macro
30/09/15, 08:34A subject posted in the forum : Water injection in heat engines: information and explanations
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 92 guests
