Triple glazing without ventilation = serious problems?
Heating, insulation, ventilation, VMC, cooling ... short thermal comfort. Insulation, wood energy, heat pumps but also electricity, gas or oil, VMC ... Help in choosing and implementation, problem solving, optimization, tips and tricks ...
User avatar
Former Oceano
Moderator
Moderator
Registration: 04/06/05, 23:10
by Former Oceano » 26/06/13, 20:07
Totally back to nature and other values ​​in a small hamlet beyond measure with the megacity of Marseilles.
: Mrgreen:
[MODO Mode = ON]
Zieuter but do not think less ...
Peugeot Ion (VE), KIA Optime PHEV, VAE, no electric motorcycle yet...
LOGIC12
I understand econologic
Registration: 28/01/08, 05:41
x 5
Re: Triple glazing without ventilation = serious problems?
by LOGIC12 » 23/02/18, 14:40
hello, it's more than safe that it's not worth it. It would be better to start by strengthening the insulation of the attic, up to 40 cm if it is possible or so we put the maximum possible without packing it.
Then the insulation of the walls should not be very thick, the ideal would be insulation from the outside, it's quite expensive, but at least it's effective.
And also, we must see if the soil is isolated (isolated screed? Otherwise, it should be known that a house more one isolates more it is necessary to renew the air, so a VMC is very often essential, except to be a real maniac opening windows several times a day especially when producing steam: kitchen showers It is good to have two or three thermometers hygrometers to realize.
It will not be profitable at all to invest in triple glazing which is very heavy and tends to darken the pieces. On the other hand put curtains and double curtains, it will hinder the heat, which rushes on the coldest walls.
To spend money would be better to invest in a VMC Double Flow, so much to do.
And then, we must see the heating we have.
  • Similar topics
    Replies
    views
    Last message
Back to "Heating, insulation, ventilation, VMC, cooling ..."
Who is online ?
Users browsing this forum : Bing [Bot] and 248 guests
