Build a voltage regulator for a wind turbine
- Philippe Schutt
- Registration: 25/12/05, 18:03
- x 33
- Philippe Schutt
- x 33
- chatelot16
- Registration: 11/11/07, 17:33
- x 264
Re: Build a voltage regulator for a wind turbine
gogol's hasar we showed this picture
big error to correct: putting several bipolar transistors in parallel does not work!
the behavior in temperature makes that it is that which is warmer which takes more current, thus heats still more and grill while taking more current than it can
to share current between several bipolar transistor you have to put a resistor in series with each emitter ... it makes a loss of power and more but it is necessary for it to work
finally today we also have the mos fet transistors which have a behavior in temperature allowing to put them in parallel without problem
and there is especially the principle of power supply with cutting which makes completely obsolete the linear regulation ... except particular need like the absence of noise in high fidelity audio material
- Registration: 17/03/14, 23:42
- x 1516
9 years have passed, he must have found the solution since
- chatelot16
- x 264
I know that my answer will not be useful to the one who asked the question 10 years ago ... but just not to leave a false thing visible to anyone
- Similar topics
- Replies
- views
- Last message
- 0 Replies
- 4467 views
Last message by mauriceboka
View the latest post
30/03/17, 07:19A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 0 Replies
- 3902 views
Last message by rifleman
29/12/15, 22:44A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 17 Replies
- 12927 views
Last message by tam20
23/12/11, 12:56A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 38 Replies
- 32441 views
Last message by vinzman
22/07/11, 17:06A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 2 Replies
- 16511 views
Last message by Pierre17800
08/03/09, 08:42A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
Back to "hydraulic, wind, geothermal, marine energy, biogas ..."
Who is online ?
Users browsing this forum : No registered users and 286 guests
