Paz wrote: I leave you in pictures the engine parts of the screw.
It is the pinion above the plastic one that broke:
We do not see the pictures at all, put them on forums using the "Attachments" function ... I will then edit your message ...
Paz wrote:Hi Beud,
Thank you for your message, the photo-elec detection is variable when it works I've seen from 17 to 50 or 100.
At the stop necessarily 0
Voila, if it can make you good day
Peace
dudu39 wrote:Bonjour à tous
I had the problem see ignition resistance piece in the burner it is still changing change three times in five years rate 162 €
It still has a lot of probes probes on this boiler with TCA 2000 burner
Compressor defective after two years taken under warranty
Three burner probes in five years tariff of 279 €
Two smoke probes in five years rate 199,20 €
A probe heats the boiler body once in five years 78
A 48 photocell €
Defective probes not even taken under warranty after six months use despite several reminders to the manufacturer
This is normal is hello the price of the probe
Three really fragile room gaskets 13,20 € piece as of December 2016
Stop pellet in ordinary iron and not stainless steel 38 €
To date the severe combustion chamber deformation I think chamber wall not thick and not stainless steel that the company that manufactures refuses to replace me for free despite several raises the price is 408 € TTC
According to comments on the internet it is not only me that these problems against the burner burns very well any brand of pellet ash really fine no clinker
I stop putting money in this burner
calculate the maintenance cost of this burner
I will do like the friend who made the purchase of a rotary burner with thick stainless steel chamber for about 1500 € this is still a good budget may no problems over two years here are my comments
have a good day
Back to "Heating, insulation, ventilation, VMC, cooling ..."
Users browsing this forum : No registered users and 212 guests
