A fuel-saving vortex turbulator: WITH
- nikolaj
- I understand econologic
- Registration: 17/08/17, 18:38
- x 14
Re: A fuel-saving vortex turbulator: WITH
Hello everyone, following my work on air cyclones: here are my basic drawings before production with stainless steel sheets of 0.5 mm or 0.75 mm or 1 mm thick ...
A mystery only perpetuates when there is refusal to study it (Georges Charpak?)
- Capt_Maloche
- Moderator
- Registration: 29/07/06, 11:14
- x 42
Hello
I just reread our 2006 tests on the subject, it reminds of good times
Nikolaj, you want to install your editing on which machine?
"Consumption is similar to a search consolation, a way to fill a growing existential void. With, the key, a lot of frustration and a little guilt, increasing the environmental awareness." (Gérard Mermet)
OUCH, OUILLE, OUCH, AAHH! ^ _ ^
- nikolaj
- x 14
Capt_Maloche wrote:Hello
Nikolaj, you want to install your editing on which machines?
Hello, on a space 4 renault and my campervan fiat Hymer 544 b 1998, as well as on other vehicles ... and it works super good ...
Hello
an easy little trick to try to check the behavior and the efficiency of a AVEC, each one to his favorite model.
it suffices to put, at the end of the hose of a vacuum cleaner, a sort of transparent hard plastic sleeve on which will be mounted the model to be tested.
It's better than a TV drama! it makes vortexes, long, short, which change at the whim of the aspiration, which also makes it possible to ascertain in which direction the vortex will be formed. I used wood ashes, for example, for their smoothness, lightness and visibility, but other products can be used as soot or smoke very black (attention anyway) The latter can be tried with this same transparent plastic sleeve to check the natural revolving direction of the engine, according to its design always and with the same precautions.
"We make science with facts, like making a house with stones: but an accumulation of facts is no more a science than a pile of stones is a house" Henri Poincaré
- nikolaj
- x 14
Janic wrote:Hello
hello, great suggestions. thank you ... my cyclones air, I try them on my camper for a week or more ... or after each full of diesel ... results? blade angle at 60 degrees = very satisfactory ...
cordially...
- nikolaj
- x 14
Hello, here is my latest work on air cyclones ...
- nikolaj
- x 14
after...
- nikolaj
- x 14
suites ... the super triple cyclone has 5, 6, and 7 blades at 60 degrees..I just ride it with a GREEN air filter ... super triple cyclone that will be included in this sports air filter competition, in steel mesh, and cotton treated for life, letting the filtered air from + 30 to 50% air, compared to the conventional filter in cardboard folds ...
Buy a Green Air Filter
Green air filters demonstrate top-class manufacturing quality and deliver extraordinary performance. For your car, better protect its engine with a Green air filter adapted to your model.
The quality of the sport air filter Green
The air filter is an essential element for the proper functioning of your engine. It allows air to pass through to cool the engine without exposing it to dust, particles and heavier elements that can damage it. Real shield against the dangers that the road represents for your engine (microparticles, dust, small stones, etc ...), the air filter allows you to drive safely.
Discover also our selection dedicated to the air filter BMC or the air filter Pipercross, also perfectly adapted to the auto competition. Among the key models regularly requested, you will find the 206 sport air filters designed by Green and other reference manufacturers presented in our shop.
https://www.diapason-motorsport.com/pie ... teur=1359#
- Moderator
- x 11060
Sacred job of cutting and folding!
Bravo!
Bravo!
- nikolaj
- x 14
Christophe wrote:Sacred job of cutting and folding!
Bravo!
hello, thank you, it's pretty hard to "roll" form, I took a galvanized steel tube of 50 mm diameter volumes about the vice, then I slowly made ends meet, then, gently with an electrician's curved nose pliers, the central parts, one by one gradually ... it is not perfectly cylindrical in the middle, but it approaches it ... the angles of the blades are good inclined, they remain stable for the guides airflow ... as triple cyclone is fully included in the air filter (engine side), I will test it on more than 400 km between honfleur and banding pican week next ... already bubbling in the water tank is more powerful, it is a sign of effective turbulence currently the last cyclone (filter background) is 60 mm, I consumed between 0.33 l and 0.50 liters of water sprayed per 100 km ...
next score soon ... thank you all for your encouragement, thanks to this site, I progressed ...
here is the photo of the model of cyclone air that was installed at the bottom of the air filter ...
now that I have mounted a filter of "competition" (GREEN ... Made in France) I have seen the difference between a classic and traditional air filter "box", with green fences and cotton treated with 'stainless steel...
cordially to all ...
- Similar topics
- Replies
- views
- Last message
- 27 Replies
- 35830 views
Last message by nikolaj
View the latest post
08/11/17, 20:38A subject posted in the forum : special motors, patents, fuel consumption reduction
- 16 Replies
- 22084 views
Last message by elephant
20/10/06, 08:35A subject posted in the forum : special motors, patents, fuel consumption reduction
Back to "Special motors, patents, fuel consumption reduction"
Who is online ?
Users browsing this forum : No registered users and 225 guests
