Cutting the edges is good, but when it is with the "rotofil" the consumption of wire quickly becomes problematic or even bulimic .....
The "other" solution is a kind of small plastic knife which is mounted in place of the spool of the roto-thread.
The trouble is that these knife dirt jams faster than their shadow (about 30 minutes), are made not to be disassembled / repaired easily (riveted without being blocked in rotation) ..... short c ' is no better / more durable than the rotofil solution.
The manufacturers of these devices have understood this opportunity to sell us these accessories me.des as expensive and fragile consumable with captive customers, .... finally the usual story, of course sold without vaseline ...
After retrieving an old ski boot from Emaus, I cut up pieces and cut new knives.
They are in (rilsan?), It is really very resistant, about 2 times thicker than the original knives ... and it works at the hair ..... size as well ..... the battery lasts for as long ... For the lifetime, I only tried it for the time of a discharge (about 30 minutes) but after this test, they are still like new!
I'll keep you posted.
DIY Tip: How to Improve a Border Size
Reason is the madness of the strongest. The reason for the less strong it is madness.
Re: DIY Tip: How to Improve a Border Size
I know that somebody I know had picked up the blades of small vegetable knives whose wooden sleeves were broken, and fitted them on the head of the cut edge but the fine metal ended up deform
later he had used the cheapest laminated steel linen often sold in boots, or when changing the brake cables of bicycles, we gave the old to this gentleman, but this one was fraying, this clothesline can be found in bazaar stores without mentioning the signs
but it seems that the clothesline was more resistant to the trimming cut but for the linen one could not say as much
cordially
cordially
For the motorcycle cable (diameter 3 mm?) I already tried on my mower to simulate the mulching tool, it vanished in (less than 5 minutes?). Fortunately I did not take him in the feet when he left !!! I never found it !!! On the other hand, by replacing it with the largest plastic roto-thread that I could find (of square section), it "held" (without locking) about a mowing of 1h30? Very good result for a few minutes, then when the plastic wire becomes too short it no longer works.
Hello, I had already seen the tool to mulcher in the small catalogs vanadium trucks that passed
It 's a shame that these trucks do not pass as often, it' s better that the lamettes are plastic, because the person I know who had used the blades of the small vegetable knives on his cut edge, one of them barred and was found planted in the wooden fence between
he and his neighbor, luckily nobody was in the garden and like it can fly away, it could have robbed 2 or 3 gardens further and hurt somebody
may be small, non - sharp, non - sharpened metal strips may do the trick
cordially
cordially
This is the principle of agricultural rotary mowers: they are never sharpened, but changed when they have too much wear. It is the velocity that causes the cut, so it remains to be seen if the speed of the trimmer is sufficient and, on the other hand, if these small blades are not dangerous, but not sharp?
View this drawing...
"Please don't believe what I'm telling you."
Re, it 's vai that I have never done this kind of tinkering, but wait for the continuation of the tests of flytox with its border cut
with its plastic blade (rilsan), but as we say all the ideas are good to take
it would be necessary to have thin metallic lamellae which can even be flexible, kind of notepad notebooks, because if the metal is bigger it weighs and risks to use the motor of the border cut, these slides can be cut in can cans for example
in short what remains of DIY
Re: Tricks: How to Improve a Border Size
It would be preferable for them to be flexible and thin, since a low inertia would greatly reduce the dangerousness of the use.
Once the shape and the nature of the steel are determined, it would be possible to use a dedicated cookie cutter to make on request ...
: 4: Hello, it is true that this kind of pieces could be manufactured once we take the piece, it seems to me that was discussed in this other topic of flytox Gardening / DIY stuff de-improve-a-mower-a-grass-t11877.html
to make the mulching tool, they also sold to the truck this type of heads for brushcutters https://www.youtube.com/watch?v=x3fAmU7efck
but I do not see a system like that on a cut edge
Hello, here's a tip all simple and even less expensive for cutting edge
and as a cutting edge
Good evening, here is a gadget found on the net https://www.eurotops.fr/coupe-bordure-piles-42022.html
and at the same time I dig up the subject
- Similar topics
- Replies
- views
- Last message
- 35 Replies
- 37575 views
Last message by Christophe
View the latest post
12/05/22, 12:10A subject posted in the forum : Garden: landscaping, plants, garden, ponds and pools
- 0 Replies
- 4968 views
Last message by Jardinierbricoleur
05/01/18, 03:15A subject posted in the forum : Garden: landscaping, plants, garden, ponds and pools
- 0 Replies
- 4141 views
14/11/17, 23:18A subject posted in the forum : Garden: landscaping, plants, garden, ponds and pools
- 0 Replies
- 3984 views
04/05/16, 19:43A subject posted in the forum : Garden: landscaping, plants, garden, ponds and pools
- 4 Replies
- 10054 views
Last message by oli 80
10/06/18, 15:34A subject posted in the forum : Garden: landscaping, plants, garden, ponds and pools
Back to "Garden: landscaping, plants, garden, ponds and pools"
Who is online ?
Users browsing this forum : No registered users and 166 guests
