Drawing for the bubbler water doping?
Tips, advice and tips to lower your consumption, processes or inventions as unconventional engines: the Stirling engine, for example. Patents improving combustion: water injection plasma treatment, ionization of the fuel or oxidizer.
Other
Pantone engine Researcher
Registration: 17/03/05, 02:35
x 12
by Other » 02/11/12, 16:18
Hello
Exactly: I looked at several montages, including yours on the thread "Pantone process: water doping or Pantone engine"! But it was Antoine G who INTRODUCED the system in France with the bubbling of water! Now, what does he say?
If you think this is the best assembly, exactly copy Antoine's bubbler and these multiple reactors.
Without taking anything away from Antoine, it is to him and David that the authorship of water doping returns. But authorship does not mean that the other montages are not improved, we have historical examples everywhere. the first men to have built a plane (flyable) the brothers wright, were quickly exceeded, Garros and Morane the first to have designed a system of pulls through the propeller were quickly exceeded by Anthony Fokker when he copied, improved the system, evolution is filled with a similar example.
In my view the most beautiful assembly is that of the tractor 42
Among the best documented tests it is auto 34 Peugeot thereafter the same travels with two other assemblies all the details consumption of diesel water, wind, dimension ect .. figures which correspond to what several other doping assemblies do.
My editing is far from being a perfection, I looked for a certain simplicity and especially something that works without having to clean too much to adjust with the least possible maintenance working on it. An assembly is often made with the material means and the tools that one has and especially the place that there around the engine, the elbow available in the exhaust pipe. Before you start, spend hours with the hood open.
In your post it is a drawing, a project and the experienced ones of this forum we try to tell you the pitfalls, the mistakes, of our experiences. The forum it is a public place to exchange experiences that helps others who make montages or adjustments ...
If you look at the number of assemblies in circulation very few make a restriction of 2/3 in admission, very little poses only a venturia which penalizes less a coarse restriction in general a simple pipe cut in whistle or a spoon, it relies on the restriction of the air filter to have a vacuum, to realize that the reactor is more functional when the air filter becomes clogged.
I could fill a barrel of junk with all the mistakes I made of all that I started again.
The drawing of David (a character that I respect) that you post above with an exhaust control, I never saw one in photos, built, to know if it is functional after 10km.
after a lived of more than 100km in doping with water you have a good idea of ​​the problems maintains and you understand why the assemblies must be in stainless steel, that the magneisme and the orientation of the north reactor it looks like the dance of the rain , folklore that I will see at the party in the reserve at Pawa Abenakis.
Go see ZAC (Berger) in your corner, he has a good experience on water doping. You will avoid many mistakes before building.
Moderator
Moderator
Registration: 10/02/03, 14:06
x 11064
Re: Drawing of the bubbler for water doping?
by Christophe » 12/03/16, 20:04
Bolt wrote:schematic diagram of water doping with the different places of possible measures to try on the way to come and discuss it on the forum
User avatar
nikolaj
I understand econologic
Registration: 17/08/17, 18:38
x 14
by nikolaj » 12/10/17, 10:30
hello here are some docs ... cordially ...
PRINCIPLE OF THE PANTONE ECOPRA NANOKIT RETROKIT ECONOKIT SPAD DOPING KIT WITH WATER-1.PNG
PRINCIPLE OF THE PANTONE ECOPRA NANOKIT RETROKIT ECONOKIT SPAD DOPING KIT WITH WATER-1.PNG (134.08 KiB) Accessed 7084 times
PRINCIPLE OF THE PANTONE ECOPRA NANOKIT RETROKIT ECONOKIT SPAD DOPING KIT WITH WATER.PNG
PRINCIPLE OF THE PANTONE ECOPRA NANOKIT RETROKIT ECONOKIT SPAD DOPAGE A L'EAU.PNG KIT (134.54 KB) Consulted 7084 times
Simple model for water spraying in engines.jpeg (34.81 KB) Consulted 7084 times
A mystery only perpetuates when there is refusal to study it (Georges Charpak?)
User avatar
nikolaj
x 14
by nikolaj » 29/03/19, 21:44
hello everyone, here are other models ...
RAIN WATER BLOWER - 4 SPACE - RELATED TO BATTERY MASS WITH 2 X 2 MAGNEET POWERFISHING FRIENDS = H2OHHO (2) .jpg
RAIN WATER BLOWER - 4 SPACE - RELATED TO BATTERY MASS WITH 2 X 2 MAGNEET POWERFISHING FRIENDS = H2OHHO (1) .jpg
trafic td 06-03-2019 vapor-7-diffuseur.jpg link project
trafic td 06-03-2019 vapor-7-diffuseur.jpg link project (70.23 KiB) Consulted 5409 times
trafic td 06-03-2019 vapor-6-diffuseur.jpg link project
trafic td 06-03-2019 vapor-6-diffuseur.jpg link project (123.69 KiB) Consulted 5409 times
trafic td 06-03-2019 vapor-5-diffuseur.jpg link project
trafic td 06-03-2019 vapor-5-diffuseur.jpg link project (280.13 KiB) Consulted 5409 times
renaut 2 liter td-spoon steam diffuser 4 holes oblongs.jpg (280.13 KB) Viewed 5409 times
renaut 2 liter td.jpg (123.69 KiB) Viewed 5409 times
User avatar
nikolaj
x 14
by nikolaj » 30/08/20, 21:50
simplified and very efficient bubbler
Fuel savers and pollution control see on my facebook page of:
July 27, 2020
Simplified bubbler with perforated flute which serves as a plunger and air inlet in the water tank ... the air circulates easily, and as the water descends ... diameter 8 mm in brass, outlet in 10x17 pvc reinforced tube with 10x14 mm diffuser.
https://www.facebook.com/palahniuk.niko ... nf&__xts__[0]=68.ARAXioTY7u5Xs9tt3RflUJxBXZUzjuOUbwaQQEG2kZW2QKByDHyUxcvWfTKVEZhqrqXyW77lS9fGy-jJrosmuBY1ZlDmwkgOj5cYsnGqzxIeM4Oxe4zvnRoPjJv0VkQn3iyg40FwVxvObCpb9dEiDrypRr8vegkf5loME11BMTQBhZke2sBMN3dms5TxdvUE9oPoP2XyQOkjQiY83iNo0a68BXVRK8HV6d8Tjdci6iNyyTFhO4R1uv_KZ__-IY_IEnUSVC0hrxtL9Pq0ZQZUvSnR28wO-Xz6Ngy4KgLihZ0DxBNj3jlpS3rKLlBzEctBLMMF5HO5-npmFcnY82foDuUVvQ
Back to "Special motors, patents, fuel consumption reduction"
Who is online ?
Users browsing this forum : No registered users and 160 guests
