Reactions following injection of water M4 BMW ...
Re: Reactions following the BMW M4 water injection ...
one does not prevent the other, it's just a technical question and therefore experimentation and mastery of the process and Audi as BMW are in their infancy (reminder Renault had used it in F1 memory!) However, these injections have little connection with the Gillier Pantone system which remains the simplest system and within the reach of any handyman.
"We make science with facts, like making a house with stones: but an accumulation of facts is no more a science than a pile of stones is a house" Henri Poincaré
- Registration: 17/03/14, 23:42
- x 1516
Tests of the BMW M4 GTS 2016 by motor legend. http://www.motorlegend.com/essai-voitur ... 19355.html
A motor more talkative than ever
This is the same block as the normal M4, with direct injection, two turbos, Valvetronic variable valve lift or double Vanos. But it also receives a new system of cooling by water spray in the intake manifolds. This lowers the temperature of the air admitted into the cylinders by about 25 ° C, allowing a substantial increase in compression rate without the risk of knocking. Suddenly, the power jumps from 431 to 500 ch, while the torque reaches the 600 Nm. Forced, performance progresses: the 0 100 km / h is performed in 3,8 s (4,1 for the normal M4),
There is no question of fuel economy, given the price of the model, it is the least of the worries of the buyer. Moreover it is logical that a power gain is accompanied by an increase in consumption and not the other way around.
For the M4 GTS 2017, even discusses BMW:
The technology of motor racing on the road: the BMW M4 GTS is equipped with an innovative system of water injection, which has been proven on the BMW M4 commissioned as a Moto GP's Safety Car by boosting its power and his couple. This system is to spray a mist of water into the intake manifold of the intake module. The vaporization of water significantly cools the intake air, and consequently the final compression temperature in the combustion chamber, thus decreasing the rattling tendency. This feature allows the 6 gasoline engine M TwinPower Turbo in-line cylinders to be used with increased boost pressure and an early ignition point. Power and torque increase as thermal stresses decrease. http://www.bmw.fr/fr/new-vehicles/M/m4- ... 4-gts.html
it's a basic analysis, everyone knows that supercharged engines like cold air; but no word on the changes in combustion caused by the presence of water before ignition.
I always had the intuition that the presence of water H2O before and at the very beginning the combustion created fragments (free radicals H * * OH, various ions) which accelerated the dismantling of the carbon chains; said in simpler, more complete combustion, faster, less unburned.
for that, you don't need a lot of water, a vaguely distributed "fog" is enough. Too much water will have harmful effects, going as far as preventing inflammation. There is therefore an optimum to be found.
- Moderator
- x 11042
In agreement with Remundo, the effect of water injection is not limited to a cooling of the intake gases!
We could also cite the reaction of "hot carbon" which begins at 800 ° C:
C + H2O -> CO2 + H2
C + H2O -> CO + H2
It explains easily why a water injection engine emits less soot (fine and less fine particles ...)
Then the sprayed water has a relaxing effect: a droplet which vaporizes at 100 ° C gains 400 times its droplet volume ... the effect is certainly not negligible on the SME ... And before 100 ° C it contributes to increase the compression ratio: the water is not compression (in "basic" physics)
BMW engineers (and others) know all this very well (and if they do not know it is that they are sacred spots!)
C + H2O -> CO2 + H2
C + H2O -> CO + H2
- x 1516
JEAN-LUC MOREAU keeps repeating in his review http://www.auto-moto.com/actualite/envi ... 43967.html
But it is the only one to proclaim it. In the other magazines auto (serious) one speaks only gain in power.
The system sold by breton touted in another subject is based on the redox magnesium and assert an average saving of 20 to 25% fuel. https://www.eco-leau.com/le-kit-hybride4all/
Why do not we find real engine tests with or without a test bench? (with real scientific protocol)
This is good because there is no gain on an already optimized engine.
Not to mention that sending water into the intake may create oxidation and mix with the oil to make mayonnaise.
In the BMW case, the injection is made only in case of extreme solicitation, so just a commercial argument.
Apparently, the real magnesium engine has not given away https://fr.wikipedia.org/wiki/Moteur_au_magn%C3%A9sium
Christophe wrote:In agreement with Remundo, the effect of water injection is not limited to a cooling of the intake gases!
C + H2O -> CO2 + H2
I think it's more like CO + H2
otherwise, on a healthy engine, no "mayonnaise" that holds up ... combustion produces water, even when there is no water injection.
What is interesting is the hardening of anti-pollution standards that brings them on it. Apparently it allows to have less costly and energy-efficient depollution systems by throttling the exhaust system (like FAP, Adblue and all kinds of gas plants ...)
- Moderator
- x 11042
Oops forgiveness yes CO ... not well awake ... the night was long ...
But the CO will rebrul quite quickly as the H2 to form CO2 and H2O ...
CO is the main "fuel" of lean gas in gasifiers ...
- Moderator
- x 11042
izentrop wrote:JEAN-LUC MOREAU keeps repeating in his review http://www.auto-moto.com/actualite/envi ... 43967.html
Good article, but where is the video?
- Moderator
- x 11042
izentrop wrote:Not to mention that sending water into the intake may create oxidation and mix with the oil to make mayonnaise.
We have never seen an engine break down faster when it was running in fog or mist ... but an engine that does not run for a long time does not like storage in too much humidity ... of course. ..
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 168 guests
