Hello,
I have a drill in my garden, which is connected to a bladder tank in my garage, which then feeds my garden and my sanitary water.
I would like to completely empty the tank in order to remove the impurities that could accumulate at the bottom, and then restart.
I do not know how to do.
Should I cut the pump from the borehole, empty the tank by the bottom tap, and just turn it back on? Or do I have to put some air back in the air at one point?
Thank you for helping me because I do not know anything about it.
I am attaching photos of my tank.
Bladder Bladder Bladder Drilling
- Attachments
- IMG_20170928_182136.jpg (422.59 KB) Viewed times 7481
- IMG_20170928_182037.jpg (386.56 KB) Viewed times 7481
Re: Bladder tank drain Drilling
If racking is usually done at the bottom of the tank, there is no reason for an accumulation of junk.
Otherwise, your procedure is correct: you drain at the bottom (pump stopped, obviously!); then, you are re-inflating to 2,5 kgs (approximately, it depends on your operating pressure [empirically, 0,5 kgs below the pressostat switch pressure]), then you start your pump again ...
"Please don't believe what I'm telling you."
- Similar topics
- Replies
- views
- Last message
- 3 Replies
- 6648 views
Last message by simply
View the latest post
07/06/20, 15:50A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
Who is online ?
Users browsing this forum : No registered users and 163 guests
