my photovoltaic panel also comes from a seller from the right corner in Poitiers ... but not sure it is the same since you do not give precision
I installed 400w peak: it rarely exceeds what I consume so it pays off well
install more and try to make the most of the rab by using hot water seems to me a mistake: hot water has much less value than electricity ... we can do it with solar thermal collectors cheaper than photovoltaics ... in winter I make cheap hot water with wood combustion
as long as there is no good large repairable and durable demountable battery there will be no cost-effective way to recover photovoltaic in rab ... making hot water is a false lead
Self-consumption: what good value for money?
- chatelot16
- Registration: 11/11/07, 17:33
- x 264
Re: Self-consumption: what good value for money?
I clearly disagree with you Chatelot the figures speak for themselves and if an exposure due south allows with a rerouting barely 5 years return on investment ca all other other forms of system.
The rerouting allows:
-avoid the cost of a storage battery at low cost increase the electric production by the surplus of panels (x3 on background noise)
- recover in a degraded form the electricity (by hot water) which in any case is used to heat an electric DHW tank that we all hold in majority (if the heating of the DHW is carried out by a thermal panel the additional cost mounting will not be profitable and the system less reliable and less efficient in winter, however I have no comparison for the DHW produced by a wood heating which is in my opinion too restrictive)
-significantly reduce the EDF bill.
-to allow better use of the electrical installation in the event of an EDF outage
-to reduce the complexity of the system which becomes feasible for any handyman.
- to a lesser extent to be in accordance with the law
For all these reasons and for the fact that an electrical panel produces as much kwh usable for the year as a thermal panel and whose cost today is much lower, it is relevant to reroute.
- chatelot16
- x 264
at home with the price of electricity and the price of photovoltaics, it pays for itself in 8 years if I consume electricity directly
the heat of wood costs me about 10 times cheaper than electricity ... so if photovoltaic has nothing better to do than hot water it pays for itself in 80 years
that's why I say that in my case using the photovoltaic rab to make hot water is hardly better than letting it lose
what is more interesting to optimize self-consumption is the intelligent control of certain devices:
double thermostat for freezers, to favor their functioning when there is a rab
emergency power inverter modify so as not to charge its battery permanently but in priority when there is a rab
the same for a large tank compressor
I wanted to do it also with a washing machine ... it would have been easy with the old one which supported being lit and cutting by continuing its program each time we turn it back on ... alas all the new machine stupid electronics that do not continue the program when you turn it back on: another progress in reverse!
chatelot16 wrote:my photovoltaic panel also comes from a seller from the right corner in Poitiers ... but not sure it is the same since you do not give precision
This is this announcement: https://www.leboncoin.fr/bricolage/1081 ... tm?ca=12_s
chatelot16 wrote:the heat of wood costs me about 10 times cheaper than electricity ... so if photovoltaic has nothing better to do than hot water it pays for itself in 80 years
I also have a wood boiler (pellets), but which manages the heating for the moment. I plan to add DHW one day, with solar thermal if possible, but I'm not there yet
- Similar topics
- Replies
- views
- Last message
- 0 Replies
- 920 views
Last message by lenay
View the latest post
23/01/24, 09:10A subject posted in the forum : Renewable energy: solar power
- 4 Replies
- 1762 views
Last message by izentrop
17/02/24, 10:27A subject posted in the forum : Renewable energy: solar power
- 9 Replies
- 1750 views
Last message by Martine24
01/12/23, 14:36A subject posted in the forum : Renewable energy: solar power
- 10 Replies
- 9810 views
Last message by zed
23/11/20, 15:52A subject posted in the forum : Renewable energy: solar power
- 8 Replies
- 9237 views
Last message by Bardal
22/07/19, 15:36A subject posted in the forum : Renewable energy: solar power
Back to "Renewable energy: solar electricity"
Who is online ?
Users browsing this forum : Yahoo [Bot] and 222 guests
