Opinion and test Hydrogen HHO kit feedback experience?
Buying well and choosing a product or service well means, in addition to being satisfied, consuming less and preserving the planet, it is essential in 2021 to buy better! Also the exchange of information and experiences makes it possible to avoid various scams and crooks. In 2021, it is essential to exchange your experiences of use, positive or negative, because the market for products and services for the consumer has never been so abundant in the history of mankind. Helping to choose better is essential because buying better means buying sustainable!
User avatar
gildas
Registration: 05/03/10, 23:59
x 173
Re: HHO experience feedback kit?
by gildas » 05/09/17, 11:13
Christophe wrote:And another video a little more "scientific" (but we could do better than that...) which shows that the gain in consumption of the HHO system is nil (what we have said from the beginning here... given the homeopathic quantities of H2 produced by HHO)... if we do not correct (quite a lot) other parameters...
https://www.youtube.com/watch?v=hOJ_eW5HOOs
It's actually an American video (I guess saw the yellow band on the road) edited and commented in French...
Which means the HHO kit works... : Cheesy:
Moderator
Moderator
Registration: 10/02/03, 14:06
x 10974
by Christophe » 05/09/17, 12:02
Gildas wrote:Which means the HHO kit works... : Cheesy:
Not sure!
It would have been necessary to cut the HHO after adjusting the other parameters to be sure... : Cheesy:
User avatar
gildas
x 173
by gildas » 05/09/17, 13:43
Here is a video of a test with HHO on a construction machine and at the end of the video, HHO deactivated...
The result is impressive on pollution..
No comments on a possible engine setting..
(dsl for the ad)
User avatar
gildas
x 173
by gildas » 30/08/19, 13:04
Hello,
Christian Fetter, fan of HHO systems, continues this time with a boat whose 40hp engine is doped with hydrogen:
(also seen on Quanthomme.fr )
Mr Fetter talks about hydrogen ionization:
http://www.hautegironde.fr/app/uploads/ ... ressed.pdf
The term ionization is also used to explain the Pantone or Gllier-Pantone systems, which means that there are similarities with HHO.
Moderator
Moderator
x 10974
by Christophe » 30/08/19, 14:08
Uh say see, H2 doping is not in the public domain since we were talking about it here long before 2013? : Shock:
The HHO kit were already marketed in 2010, when this topic was created...
User avatar
GuyGadebois
Registration: 24/07/19, 17:58
x 982
by GuyGadebois » 30/08/19, 15:14
Christophe wrote:Uh say see, H2 doping is not in the public domain since we were talking about it here long before 2013? : Shock:
Excerpt from Logikko:
"Similarly, the consumption of these vehicles has dropped. Except in one case: the vehicle tested was overloaded and the driver was driving too "sporty". This has led us to emphasize to drivers that they will get the best results if they adopt a moderate driving style without overstressing the engine and without excessively heavy loads.."
Which means that the system works when the driver has a light foot, so it does not work as a fuel saver because by having an economical driving, we already drastically lower our consumption!
“It is better to mobilize your intelligence on bullshit than to mobilize your bullshit on intelligent things. (J.Rouxel)
"By definition the cause is the product of the effect". (Tryphion)
"360 / 000 / 0,5 is 100 million and not 72 million" (AVC)
Moderator
Moderator
x 10974
by Christophe » 30/08/19, 16:09
Well, I'm testing the 5 L/100 with a 150 2005CV engine and a 1.6 T body in a hilly region by adding a little gasoline, see figures here consume-less-car/diesel-car-consume-less-with-a-little-of-sp95-t5849-920.html (page + and -)
User avatar
GuyGadebois
x 982
by GuyGadebois » 30/08/19, 16:31
Christophe wrote:Well, I'm testing the 5 L/100 with a 150 2005CV engine and a 1.6 T body in a hilly region by adding a little gasoline, see figures here consume-less-car/diesel-car-consume-less-with-a-little-of-sp95-t5849-920.html (page + and -)
Went from 4.1L/100 to 3.3L/100 with the EcoL'Eau kit in an equally hilly region. Back from Germany, I still gained on the previous trip by going from 4.3L/100 to 4.1L/100.
User avatar
thibr
I posted 500 messages!
Registration: 07/01/18, 09:19
x 269
by thibr » 30/08/19, 16:33
"modern" cars only feed the horses we use, not 150 in eco driving : Wink:
User avatar
gildas
x 173
by gildas » 30/08/19, 23:21
The Teknew process (name cited in the press article) is probably not only H2, there is presence of "white smoke" as said in their video at 1'50: (here it is a descaling agent hho engine)
This white smoke or rather aerosol * could well be the keystone of the success of the HHO generators mounted on the racing boats of Rouen. This year again about 35% fuel economy of competition:
Congratulations to Team VSI boat number 50 equipped with the HHO ECOLION kit for their 5th place and especially their fuel economy for having consumed 12l per hour against 18L per hour in normal operation, having hardly polluted.
There is still some adjustment to go down a little more but the goal is reached!! To be continued and congratulations again!!!
Team VSI Racing - 24 hours motorboating of Rouen
[0]=68.ARC2DlSDimt_LyiGTRo1RfVovC4Ah7FSaETwrB3nm0rlazindm_RY3Xd8WXynxBHvieucItjDgpEhHVZ7MvdyplHDiHScaoREeR2R5KScB9qcXI_QB0DpMEEb22hfH1E11MAVYTdYYwVg9ep_0SkAZkcKNF9ZTGCAM2aCTc5Mz62GMLou1MLZCDc6mmYmFu5JBwoySpOqI-FYcD4aqzGLX0_Bussz54P2e9ZpLp1DczJ5WgNXURln3BW_7r2tTebLX6f4J_4I6KeRFLaKZ6kQhZHUnTuPcClJtoNmbTDno0nBsOGmxOIibSvf5z5nxU16SSco4bIq8A3zZe8ibGKUj91&__tn__=-R
Let's be realistic, when you see under the hood the HHO generator of a boat, it is surely powered with a 12v battery which will generate at best a liter or two of HHO per minute. A homeopathic dose compared to the air sucked from the 70hp engine running at 6000 rpm!
What is on the other hand very probable is the ionization of the aerosol composed of misted water and electrolyte which must also greatly help in the ionization.
At 6000rpm there must be a very strong depression like in a Pantone...
It's an assumption, there is no energy in a volume of air composed of 0,1% H2...
What cites Guy Gadeboismay be an oversight to update the site of the Logikko site.
  • Similar topics
    Replies
    views
    Last message
Go back to "Reviews and tests of products and services." Good deals, scams and scams. What to choose, reviews and purchase tests to choose better! "
Who is online ?
Users browsing this forum : No registered users and 35 guests
