Hello,
For a long time I have been thinking of building a thermal sensor using alveolar polycarbonate and I wonder if anyone has ever tried the operation.
Idea of sensor
- I learn econologic
- Registration: 04/09/17, 00:42
Re: Sensor idea
Hello,
you have to be wary like the plague of great ideas that no one has ever thought of. Especially if you haven't experienced them yourself. Human beings learn a lot by imitation: walking, smiling, talking etc ... have you ever seen something close to your idea? was it working to satisfaction with regard to the means invested?
yves
yves
ignored: obamot, janic, guygadebois... air, air. We are not (yet) on Qanon Ben, if in fact
- Moderator
- x 11060
Re: Sensor idea
This has already been thought through and done ...
The concerns with the use of polycarbonate in solar thermal panels are:
- UV resistance (treated but only on 1 surface generally therefore not to be mistaken),
- Sealing at the ends of the panels,
- The temperature resistance over time (80-90 ° of water in summer ...)
- Pressure resistance (if not drainback, see: Solar-thermal / solar-system-to-drain-drainback-why-c-is-better-t8197.html et Solar-thermal / drain-back solar-self-emptying t12645.html)
- Mosses and molds (externally it is fairly easy to clean but much more difficult internally: the water used must be very sterile)
In addition, polycarbonate is no longer "given" at all ...
Better to use EPDM which is not transparent therefore (like flexible pool panels ...), see: Solar-thermal / who-with-hot-from-EPDM-to-pool-t7783.html
Otherwise, a real copper panel with window and pressure holding as it should be 150-200 € / m2 currently ... so not at all that DIY is still interesting ...
Re: Sensor idea
Christophe wrote:This has already been thought through and done ...
Thank you for this precious information Christophe. Do you know who tried the experiment?
- Moderator
- x 11060
Re: Sensor idea
Not specifically but research on forums gives these 2 subjects give a lot of information on the PC used in solar panel (not great):
Solar-thermal / search-plate-coating polycarbonate-solar-panels-t3171.html
Solar-thermal / help-on-the-choice-for-glass-panel-air-heat-t7348.html
ps: we are familiar with one forum
Re: Sensor idea
Thanks for the links. Too bad, I did not see what it gave to the final.
Christophe wrote:Not specifically but research on forums gives these 2 subjects give a lot of information on the PC used in solar panel (not great):
- Similar topics
- Replies
- views
- Last message
- 11 Replies
- 7905 views
Last message by Christophe
View the latest post
03/12/15, 20:22A subject posted in the forum : Solar thermal: solar collectors CESI, heating, hot water, stoves and solar cookers
- 0 Replies
- 2885 views
Last message by barjoh
22/02/13, 19:44A subject posted in the forum : Solar thermal: solar collectors CESI, heating, hot water, stoves and solar cookers
- 3 Replies
- 8717 views
Last message by Soreo
10/08/09, 10:12A subject posted in the forum : Solar thermal: solar collectors CESI, heating, hot water, stoves and solar cookers
Back to "Solar thermal: solar collectors CESI, heating, hot water, stoves and solar cookers"
Who is online ?
Users browsing this forum : No registered users and 139 guests
