Hello,
Simple assembly to water my lawn: Pump, Press control and automat.
Between 2 watering cycles - spaced 24 hours apart - the Press Control switches to "Off". If I manually reset the Press Control, it goes "On" and I can start a watering cycle. Note that I have no problem of lack of water (well on groundwater with cycles> 1 hour without any problem)
So I assumed that the press control detected an absence of water in the column between it and the pump. The reason could therefore be a fault on the non-return valve of the pump. So I put a brass valve on my column between the pump and the Press Control to prevent the column from draining. This has not changed anything.
What to do? I do not know anymore. Thanks for your help
Press control off between 2 cycles
Re: Press control off between 2 cycles
Me personally I would transfer the press control
The all-integrated-things-that-do-everything-but-we-don't-know-how I don't like, it's a source of pain.
But hey it's not the answer you expected I guess.
Hi,
At the time I listened to my gardener wanting to have 2 taps in the garden supplied with water from the well ... And actually I am asking myself the question of turning the press control because it is a beast of sorrow whose hard to understand how it works.
Now how do I - electrically - transfer the press control? I saw that the cable coming from the pump entered the press control and effectively the wiring goes back to the PLC. is it enough to restore electrical continuity?
physically once the press control is no longer powered it is neutralized or do I have to physically transfer it? In the latter case, I noted that the pump went up to the press control was at 32 while the press control output was at 25. How should I do?
thanks for your help
You unplug it electrically, it can stay in place it will no longer have any role. However, it must be replaced by a pressure switch.
Thank you for your advice. I imagine that the pressure switch will regulate the pressure of the pump, depending on the use ... It mounts on the water distribution I imagine .... well it only remains for me to spin at store to make me explain this
- Similar topics
- Replies
- views
- Last message
- 9 Replies
- 1323 views
Last message by Forhorse
View the latest post
11/02/23, 07:51A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 0 Replies
- 4806 views
Last message by mike84000
11/03/19, 20:59A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 14 Replies
- 16328 views
Last message by SKR
29/11/18, 22:16A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 3 Replies
- 6544 views
Last message by Ahmed
18/05/18, 22:18A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 7 Replies
- 11543 views
Last message by Bardal
08/04/18, 18:07A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
Who is online ?
Users browsing this forum : Bing [Bot], Majestic-12 [Bot] and 158 guests
