Hello everybody
I am new to the forum and looking for some advice.
I recently acquired an old house whose walls are 55 cm thick, the house is on 3 floors. The previous owner has had double glazing installed on almost all levels. I am working on the insulation of the roof which needs to be redone (over 30 years). The house is currently ventilated in a natural way (you can really feel the drafts). I am going to finish installing double glazing and all this will help to strengthen the seal. I don't intend to insulate the walls because I read that on these old houses, it was not necessarily a good idea because they "breathe", moreover I can only insulate from the inside. Here it is, it is to paint the picture.
My question is about ventilation. I would like to install a double flow vmc and I read that it was necessary to extract the air by the humid rooms and to renew it by the dry rooms. The problem is that I don't have wet rooms on the top floor, there are only rooms. Should I still place an extractor on this level (in the small hall formed by the arrival of the staircase for example)? Are passageways like stairs to be ventilated and in what direction?
Thank you in advance for your precious advice.
VMC DF-story house ...
Re: VMC DF and two or more storey ...
1) The rooms are much wetter than you think: weigh yourself in the evening and in the morning, before having pissed! You will see the difference in weight which is equal to the amount of water transpired / breathed overnight.
So if your house is tight, for me, the answer would be yes, you have to extract it in the bedrooms.
Especially without insulation: risk of condensation points in the coldest corners! Paper that peels off and especially mold - some of which can be allergenic (spores).
Dust mites also like humid atmospheres ...
2) In your airtight house, you have to "imagine" the air circuits that will be made between the insufflation nozzles and the extraction nozzles. Make sure that these flows "sweep" most of the rooms, if possible diagonally.
For example, typically: blowing into a "dry" room at the corner furthest diagonally from the door - passage under the door (possibly cut if too close together) - sweeping of one end of the corridor - entrance under the door of the wet room - extraction in a diagonally opposite corner.
I am not a specialist. This is only a DIYer's opinion!
Back to "Renovation, construction and real estate work: help, advice and methods ..."
Who is online ?
Users browsing this forum : No registered users and 77 guests
