milou wrote:hello yes good the teeth of the fork its a little too wide but I have two arms of rivers which feeds the mill a arm of rivers of 4 m wide which passes in the mill for the waterfall, and at 30 meters upstream another river 6 wide, which can feed for a higher flow the other arm of the river which feeds the fall a (condition to repeat winnowing) and for alls tell you that summer and winter I have a constant flow of water at my mill I am in a marshy region I do not lack water even at the height of droughts. (twice water police (ddh) agents came to take photos and record flows of water and photos good to see later.
Already it is not the width of the river that counts, but its flow.
Then, and you must know it since agents came to your home, even if you have a water right you have no right to take the entire flow for your mill.
With a "standard" mill (say a wheel 1m wide and 5m in diameter) if you can support the consumption of 4 houses whatever the period and 365 days a year that would be good.
I think you do not realize the poor performance that has a paddle wheel ... (which must still be subtracted from that of the generator)
