Calculation engine operation condenser pump Guinard / ELEM
Work concerning plumbing or sanitary water (hot, cold, clean or used). Management, access and use of water at home: drilling, pumping, wells, distribution network, treatment, sanitation, rainwater recovery. Recovery, filtration, depollution, storage processes. Repair of water pumps. Manage, use and save water, desalination and desalination, pollution and water ...
User avatar
delnoram
Moderator
Moderator
Registration: 27/08/05, 22:14
by delnoram » 05/07/15, 20:18
yes I think we're going around in circles :|
Otherwise I found that : Arrowd: which brings us back practically
to the previous calculation
On an electric motor (Guinard water pump) from 750 W (1CV), 220V, 50 Hz, 1250 RPM: What value of starting capacitor should be adopted? The original value is no longer readable and with 16 micro Farad 400 V the engine refuses to start alone, it must be launched by hand.
Thank you for answering me.
You need about 56μF / 250V or 400V ...
"Thinking should not it be taught in school rather than to make learning by heart the facts that are not all proven?"
"It's not because they are likely to be wrong they are right!" (Coluche)
Moderator
Moderator
Registration: 10/02/03, 14:06
x 11060
by Christophe » 05/07/15, 21:38
Yes on.turn a little round: normal for a pump lol
Didiou 56 uF it's a lot ... all the 600 engines at 800w that I saw still had only 16 uF or 20 uF
Good if my multimeter seems to work I had a doubt: I measured a new capacitor from 2uF to 1,95uF ...
I ordered 4 capacitors: 10, 15, 25 and 40 uF ... history to do some tests and combinations in parallel editing
Moderator
Moderator
x 11060
by Christophe » 15/07/15, 12:18
Christophe wrote:I ordered 4 capacitors: 10, 15, 25 and 40 uF ... history to do some tests and combinations in parallel editing
Here I received the 4 operating capacitors for testing:
The multimeter capacimeter gives about 15 μF for the 15 μF:
The 2 other than I tested above were cooked ...
Anyone know why there are 4 outputs (the 2 G and D connectors are connected in the capacitor, we can wire it from 4 ways gd: up-up, down-down, up-up, up-down) ?
To easily do paralleling can be?
Moderator
Moderator
x 11060
by Christophe » 15/07/15, 13:04
I will try the following editing: 10μF, 15μF, 25μF, 35μF (25 + 10), 40 μF, 50 μF (40 + 10) ...
I'll tell you from what capacity the pump restarts ...
User avatar
Registration: 04/12/08, 14:34
x 1641
by Macro » 15/07/15, 13:31
That it redémre is a thing. That it maintains its regime in charge is another ... Reminder to charge a centrifugal pump:
it must be fed correctly (if possible with a height of fluid just below its axis) and have it flow freely with the largest flow possible it is in these conditions that it draws the most intensity.
The only thing safe in the future. It is that there may chance that it conforms to our expectations ...
Moderator
Moderator
x 11060
by Christophe » 15/07/15, 16:21
Just macro: I planned to do startup tests with a hydraulic load ...
I no longer remembered that the maximum power of a pump was with the minimum discharge height (logically physically it should be harder, so more amperage, start a pump with X m of water column above no ?).
In short thanks for this reminder. I will try like this (with a wattmeter taken to control consumption).
This pump will be mounted on a suppressor group tank with pressure switch ... once repaired it will therefore turn between 1.5 and 3 bars approximately.
ps: what is on it is that considering the volume of the capacitor of origin, this one had not more than 20 μF ...
Moderator
Moderator
x 11060
by Christophe » 16/07/15, 15:43
I just tested all the capacitors on the engine, it does not work better: whether the capacitor is connected or not, the motor reacts the same: it blocks at startup between 0 and 2 seconds and the thermal fuse triggers ...
Example with 2 // capacitor: 25 + 10 = 35 μF
One of the 3 cables to the engine was unsoldered, I sold it back but no change ...
So there is another problem ... I open another subject ...
Moderator
Moderator
x 11060
by Christophe » 16/07/15, 16:35
  • Similar topics
    Replies
    views
    Last message
Go back to “Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ... "
Who is online ?
Users browsing this forum : No registered users and 182 guests
