How does the HHO Hydrogen gas in an engine?
Tips, advice and tips to lower your consumption, processes or inventions as unconventional engines: the Stirling engine, for example. Patents improving combustion: water injection plasma treatment, ionization of the fuel or oxidizer.
Is the engine a HHO a scam? |
You can select 1 option
Consult the results
gromo74
I discovered econologic
Registration: 26/01/10, 13:40
by gromo74 » 05/01/12, 18:10
The engine works with pistons, which advance and retreat quickly at a constant rate. When a piston moves back, it will create a vacuum that allows to suck air and fuel towards the inside of the engine. As it moves forward, the air / fuel mixture will be compressed and a candle will ignite the start of combustion. In a perfect engine the start of the combustion must be done only when the compression of the piston is maximum. But, in fact, most engines fire too early and do not burn all the fuel completely. This will create inefficiency, increase fuel consumption and more pollution.
When the hydrogen mixes with your fuel, it will increase the octanes and the compression needed to ignite the air / fuel mixture. In this way, the piston must compress the fuel more completely before it comes on, and the additional hydrogen will allow better combustion and a reduction of CO2 emissions. It also adds a little more force to the engine.
See the video here
hho-plus.com/product.php?id_product=11
User avatar
Moderator
Moderator
Registration: 13/02/07, 22:38
x 839
by Flytox » 05/01/12, 19:21
Hello gromo74
Tape HHO in the search engine. You will see that the subject has been treated many times .... and that nothing spectacular to expect from this thing .... if not waste time trying to prove minimal improvements that are anyway in the margin of error of the measure.
I hope you're not here to sell this stew. : Mrgreen:
Reason is the madness of the strongest. The reason for the less strong it is madness.
User avatar
Moderator
Moderator
x 839
Re: How Hydrogen Hho Gas Works in Cars
by Flytox » 05/01/12, 19:33
gromo74 wrote:The engine works with pistons, which advance and retreat quickly at a constant rate. When a piston moves back, it will create a vacuum that allows to suck air and fuel towards the inside of the engine. As it moves forward, the air / fuel mixture will be compressed and a candle will ignite the start of combustion. In a perfect engine the start of the combustion must be done only when the compression of the piston is maximum. But, in fact, most engines fire too early and do not burn all the fuel completely.
On a recent production gasoline engine, if there is an "error" in the ignition advance, it is very low (and corrected by the knock detector) and it is in the delay direction, because too much advance rattles sooner or later and this can destroy the top engine. It is a way of securing / making an engine more reliable. For full use of a series motor, the safety margin is reduced and the maximum advance tolerance is set (if possible : Mrgreen: ).
User avatar
elephant
Registration: 28/07/06, 21:25
x 7
by elephant » 05/01/12, 19:34
I strongly advise you to read the subject "improved electrolysis"
https://www.econologie.com/forums/electrolys ... t1228.html
254 healthy and exciting reading pages on the various essays that participants of forums have performed.
Basically:
it seems that it serves a little on the big engines badly damned US, but that it does not serve much on the optimized cars of European stingy.
The conclusion of many is that there is no way to generate enough gas with our alternators to achieve noticeable improvement. Out of habit, we reject any "testimony" from people who sell it.
elephant Supreme Honorary éconologue PCQ ..... I'm too cautious, not rich enough and too lazy to really save the CO2! http://www.caroloo.be
oli 80
Registration: 02/01/09, 17:23
x 113
by oli 80 » 03/10/14, 21:08
Good evening, here are doc found on the net http://francois.delboca.free.fr/drycell/index.htm
here is a forum specialized in this area of ​​hho
http://le-forum-des-utilisateurs-de-gen ... ser=395832
I do not know much but I bring what I found on the net if it can help
cordially
User avatar
Registration: 22/08/09, 22:38
x 5538
Re: How does HHO Hydrogen gas work in an engine?
by Obamot » 06/10/14, 13:59
gromo74 wrote:The engine works with pistons, which advance and retreat quickly at a constant rate. When a piston moves back, it will create a vacuum that allows to suck air and fuel towards the inside of the engine. As it moves forward, the air / fuel mixture will be compressed and a candle will ignite the start of combustion. In a perfect engine the start of the combustion must be done only when the compression of the piston is maximum. But, in fact, most engines fire too early and do not burn all the fuel completely. This will create inefficiency, increase fuel consumption and more pollution.
See the video here
Pub!
(why put a slogan in your signature, displaying the same link if it's supposed to ask questions, and why not display the color clearly !!)
  • Similar topics
    Replies
    views
    Last message
Back to "Special motors, patents, fuel consumption reduction"
Who is online ?
Users browsing this forum : No registered users and 118 guests
