moinsdewatt wrote:Hic wrote:...
to get mechanical 1Kw on the axis,
since the system works in repulsion,
it will take 2 fields in opposition of the same power,
which represents 2 times the mechanical power and
therefore double the "normal" consumption
Return to your pack ice and stop giving yourself false problems.
it's a real problem
in a repulsion system, it is compulsory to supply energy to the two opposing fields and to the same energy level,
therefore this is double the mechanical power in "your normal"
This logic is held in the case of permanent magnet motor,
magnets that do the same job as the mechanical power on
on the motor axis, in addition to the power consumption.
but does not stand for a coil motor.
900W mechanical for 1KW electric which normally cannot provide sufficient energy for these 2 opposing magnetic fields with equal powers of 1Kw each.
nobody makes you think !!!!!
if you don't want it
