1er step into the unknown, Electric Motor Differential Analysis
Innovations, ideas or patents for sustainable development. Decrease in energy consumption, reduction of pollution, improvement of yields or processes ... Myths or reality about inventions of the past or the future: the inventions of Tesla, Newman, Perendev, Galey, Bearden, cold fusion ...
User avatar
hic
Registration: 04/04/08, 19:50
x 5
by hic » 07/08/14, 09:47
1er step towards the unknown, Electric Motor Differential Analysis!
An electric coil motor can not operate fully according to the theory
Principle to know
If one opposes in repulsion,
a magnet of 10g to a magnet of 1g,
what will be the repelling force, 1OKg or 1Kg? Survey
Differential analysis!
According to the current theory
If we inject 1Kw into an 1Kw engine,
it will repel at mechanical 1Kw
But in practice,
In this case, we can not have simultaneously
1Kw on the stator and 1Kw on the rotor
the electric Kw will be divided into 2,
500W on the stator, 500W on the rotor,
to get 500w mechanical util
When the permanent magnet motor, it works perfectly,
since we oppose a power of repulsion magnets
at the same level as the electric power injected
Here in practice,
1Kw electric injector is injected on the stator, the permanent magnets of the rotor repel mechanical 1Kw,
to get 1Kw mechanical util
Conclusion
The coils of an electric motor with coils do not behave like permanent magnets.
"Let food be thy medicine and thy medicine be thy food" Hippocrates
"Everything has a price has no value" Nietzche
Torture for Dummies
Forbid to express the idea that the field is acceleration (magnetic and gravitational)
And you get your patent mental torture option executioner successfully
User avatar
Forhorse
Registration: 27/10/09, 08:19
x 360
by Forhorse » 07/08/14, 09:59
Speaking of electric motor, did you see the engines of the new AGV train?
Obviously these are motors called "brushless" which for a volume ultimately not so large that it develops 1000hp at 4000rpm
It's enormous !
The biggest electric motor I saw in my career was 600ch and it was about the size of a car.
User avatar
hic
x 5
by hic » 07/08/14, 10:16
Torture for Dummies
moinsdewatt
Registration: 28/09/09, 17:35
x 554
Re: 1er step towards the unknown, Electric Motor Diffen Analysis
by moinsdewatt » 07/08/14, 12:52
Hic wrote:1er step towards the unknown, Electric Motor Differential Analysis!
At the bear,
You will take courses in electrical engineering to explain your nonsense.
User avatar
hic
x 5
by hic » 07/08/14, 13:45
I have taken courses!
Should you learn the fancais?
I repeat my question!
How is it possible that an engine can generate mechanical 1Kw on the axis,
by injecting him only 1Kw electric
So as to have a mechanical 1Kw force on the axis,
It takes 2 equal magnetic fields of 1KW magneto-mechanical EACH,
isssus an electrical power of 1KW every !!!!!!!
We note that
That's what you get on a permanent magnet motor,
1kw élecrtique + 1KW in magneto-mechanical repulsion of the magnets of the rotor = 1KW mechanical on the axis.It is OK!
and therefore a total of 2Kw magneto-mechanical in repulsion for mechanical 1KW on the axis
but on a motor with coils, the electric KW can not convert to 2 1KW magneto-mechanical
unless it is "like" the multiplication by zero of the buns or the wine! MAGIC!! but that is the domain of faith : Evil:
If you do not understand it is that you do not want to understand
it's closing minds !!!
See you soon
At the bear,
make an effort! : Mrgreen:
Torture for Dummies
User avatar
Forhorse
x 360
by Forhorse » 08/08/14, 09:09
Well already a magnet does not have a power, but a force, and it probably does not measure in watts.
So if you have actually taken electrical engineering courses, there are gaps or you have to revise.
moinsdewatt
x 554
by moinsdewatt » 08/08/14, 12:23
Hic wrote:I have taken courses!
We note that
You do not understand anything about electrical engineering.
Go see you elsewhere.
And at Alsthom they make hundreds of MW engines that work quite well.
Whatever you say.
User avatar
hic
x 5
by hic » 08/08/14, 12:30
Forhorse wrote:Well already a magnet does not have a power, but a force, and it probably does not measure in watts.
A coil motor with no magnets, we do not care!
could you come back to the main subject ^
to get mechanical 1Kw on the axis,
since the system works in repulsion,
it will take 2 fields in opposition of the same power,
which represents 2 times the mechanical power and
therefore double the "normal" consumption
Torture for Dummies
moinsdewatt
x 554
by moinsdewatt » 08/08/14, 12:43
Hic wrote:...
Return to your pack ice and stop giving yourself false problems.
User avatar
hic
x 5
by hic » 08/08/14, 12:45
You have a problem!
Everything works very well,
but you did not understand that there is a puzzle to be solved
No kidding? did not you understand the question?
and I have nothing against "Alsthom": mrgreen: you are "kid" there
We note that
Whatever you say.
Torture for Dummies
Go back to "Innovations, inventions, patents and ideas for sustainable development"
Who is online ?
Users browsing this forum : No registered users and 64 guests
