Indeed the resistance is in series with the consumer.
I was wondering if the condo would be enough to start an engine, a pump for example?
Today I tried the last diagram with a changeover relay and a 60W bulb.
The wind turbine simulated by a 10A charger, a charged battery, it sizzles and the bulb lights up strong.
When I draw 100A on the battery for 2 seconds the lamp goes out, and it comes back on 20 seconds later (approximately).
A wind turbine at home: Regulation for battery
Bonsoir
So today I made good progress. After various tests it turns out that the alternator regulator that I had is out of order ... That's what seemed to me.
So I started to perform the assembly with the Mosfet (diagram in my first post) but with some modifications because it was not functional. I am not quite finished but all the first part of detection is OK. More than the power part with the mosfet to be wired
I want you to juice.
Good night,
Good night,
- Grand Econologue
- Registration: 10/10/13, 16:30
- x 189
Hello Roro04 and everyone,
Here is an assembly which I carried out with components of recovery. He has been in office for a few weeks.
In standby it consumes 0.1 milliamperes.
The dissipation consumer can be a pump, at the moment I run fans.
With Radj we have an adjustment range of about half a Volt, the low threshold must be just above the no-load voltage of the charged battery. (a cloud passes and it stops immediately)
A setting on R7 is provided to adjust the high threshold without modifying the low threshold.
The on and off pushbuttons serve as remote control, only in the operating range, it is convenient for the settings.
it can also work as an adjustable "cut-off" for a lamp, by removing the R7 link.
It's "Sunday DIY" ...
- Similar topics
- Replies
- views
- Last message
- 4 Replies
- 909 views
Last message by sicetaitsimple
View the latest post
23/10/23, 10:04A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 4 Replies
- 1954 views
Last message by Remundo
29/01/23, 19:06A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 15 Replies
- 6026 views
Last message by BaudouinLabrique
26/05/23, 19:04A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 2 Replies
- 7456 views
17/05/23, 14:56A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 1 Replies
- 3239 views
Last message by izentrop
30/06/18, 07:00A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
Back to "hydraulic, wind, geothermal, marine energy, biogas ..."
Who is online ?
Users browsing this forum : No registered users and 107 guests
