Small infographic that gives the consumption of water to produce 1kg of some common foods:
Insane little difference between eggs and chickens !! Is not it?
Water consumption per food
- Moderator
- x 11046
christophe hello
Unlike other products presented which are finished products, the egg is a fetus that should be compared to other animal fetuses and the proportionality would be (reduced to weight) probably very close. I would be curious to know how this calculation (which seems to me more than excessive) was done.Insane little difference between eggs and chickens !! Is not it?
not quite! This is the overall consumption that comes from rain and waterlogged land or groundwater. The goal is to emphasize the disproportions to achieve the same result between 1 kg of potatoes and 1 kg of bidoche, while the problem of drinking water may become a global issue in the coming years. (this is already the case in some regions)The methodologically most shocking thing about the construction of this painting is that the use of rainwater by plants, which would in any case have fallen, and the use of rainwater to produce artificially, are placed on the same plane.
- Moderator
- x 11046
Janic wrote:I would be curious to know how this calculation (which seems to me more than excessive) was done.
Maybe by visiting the source at the bottom of the image?
I find it more relevant to compare the land areas needed to produce a kg. For example the water used to make 1 kg of pdt will anyway return in the environment by evaporation, infiltration, use by the plant but it will return anyway in the environment even the water contained in the pdt that we eat.
On the other hand 323 m2 for 1 kg of beef or 6 m2 for 1 kg of vegetables this is not at all the same thing.
http://www.forum-metaphysique.com/t9442 ... de-cereale
obviously it is not possible to be limited to one or two parameters. What is absurd (especially in ecology) is to support consumption behavior as catastrophic for humans as for animals sacrificed for the sole pleasure of taste egoistic. (selfish behavior found among smokers, drinkers and other addicts)
- Registration: 28/09/09, 17:35
- x 554
Re: Water Consumption by Food
Christophe wrote:Small infographic that gives the consumption of water to produce 1kg of some common foods:
and how many liters of water for a liter of Champagne?
- Moderator
- x 11046
For beer I think it's 2 to 3L about ... but I do not know if it's the overall balance sheet figure or only the manufacturing figure!
- Similar topics
- Replies
- views
- Last message
- 11 Replies
- 19981 views
Last message by Christophe
View the latest post
09/12/16, 00:45A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 22 Replies
- 32690 views
Last message by moinsdewatt
28/07/19, 09:12A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 8 Replies
- 10300 views
Last message by zozefine
14/07/10, 23:21A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 53 Replies
- 42945 views
12/03/16, 15:21A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 1 Replies
- 7384 views
Last message by ThierrySan
27/02/07, 10:03A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
Who is online ?
Users browsing this forum : No registered users and 154 guests
