Analysis of the wet combustion, DHC Software
Water injection in thermal engines and the famous "pantone engine". General informations. Press clippings and videos. Understanding and scientific explanations on the injection of water into engines: ideas for assemblies, studies, physico-chemical analyzes.
User avatar
gildas
Registration: 05/03/10, 23:59
x 173
by gildas » 29/05/13, 21:14
Flytox wrote:
The high pressure injection improved performance okay, but mostly changed sized proportions of particles rejected .... especially with a strengthening of the amount of the fine / particles dangerous to health.)
A priori, there is the solution to change the injection timing, not particles but many NOX.
And NOX there is this:
http://fr.wikipedia.org/wiki/R%C3%A9duc ... %A9lective
User avatar
Moderator
Moderator
Registration: 13/02/07, 22:38
x 839
by Flytox » 29/05/13, 22:11
This is a complicated solution, dear ... that appeals to automakers ..... they will be able to justify a greater sale price. After this is the only solution?, Best suited etc .... it is to see. : Mrgreen:
Reason is the madness of the strongest. The reason for the less strong it is madness.
Other
Pantone engine Researcher
Registration: 17/03/05, 02:35
x 12
by Other » 29/05/13, 23:30
Hello
We need to know why the old, who shoveled the chabon in boilers of locomitves took time to water copiously?
Apparently it was burning better, more heat? other say it a little threadbare and the dust makes it less black facial locomotive driver.
There was certainly a good reason to shower coal
He had no computer, but he knew things that were lost over the years (also recalls that have traveled with a locomotive steam coal when it passed in a tunnelled)
Moderator
Moderator
Registration: 10/02/03, 14:06
x 10973
by Christophe » 27/01/14, 13:28
Update explanatory .pdf SMC software Remi Guillet: https://www.econologie.info/share/partag ... jLRvXE.pdf
User avatar
chatelot16
Registration: 11/11/07, 17:33
x 264
by chatelot16 » 27/01/14, 13:47
Andre wrote:Hello
coal fire on a grill is pretty special
coal absorbs little water, little is watered without the same problem as wood
what would be the advantage of wet coal? eg less risk breaking fine particle between the grate bar ... or less risk at every pelete fine dust flies directly without burning in the fireplace
Another possible reason: increase the duration of life of the grate bar
  • Similar topics
    Replies
    views
    Last message
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 115 guests
