Article econology AUTOBIO on doping in the water!
Water injection in thermal engines and the famous "pantone engine". General informations. Press clippings and videos. Understanding and scientific explanations on the injection of water into engines: ideas for assemblies, studies, physico-chemical analyzes.
etienne34
I learn econologic
I learn econologic
Registration: 17/11/13, 12:27
by etienne34 » 21/11/13, 08:38
but you could also try to inject steam just upstream of the valve to clean ..... difficult / complicated
Yes hardly possible given the situation. + In the valve and the whole system is Quiche behind the engine, invisible, inaccessible.
reverse the position of the EGR valve so that it is after the exchanger and not before.
The problem is that the valve opens at low engine speed. So it shall prevent vapor happen when one climbs in the towers.
Somehow + general, this is a prob to use the valve at the same time that doping water. Solvent by blocking open (maybe ... to see how the electronic acts).
I think 2 use of the EGR system:
-inject the mist coming out of an econokit type bubbler into the EGR exchanger instead of the ldr. This is then bypassed. The mist (which is not vapor in the strict sense of the term but liquid water, if I understand correctly) is charged (or simply turns into "real" vapor on contact with the gas and comes out to be injected into the gas. air duct conventionally Problem: loss of the cooling function of the exchanger since the mist is hot enough (although, I do not know the temperature of the ldr when it comes in if it is the same: 40 -50 °).
Another problem, and that is my lack of chemical XP / phys, fog circulate it to you as well as ds ldr exchanger. Appeal to those who have already tested. otherwise I'll buy can be a occas pr experiment.
-Use the gas out of the egr (dc ds low regimes) to simply enter the bubbler, but it will require a reactor.
Honestly the more I try the steam, the less I feel I understand. All I see is that the settings are so complex (type of metal that will pass through the fog that can reduce pressure ...) I'll take the time in this case. It's worth in any case qd I see all the benefits and potential of steam (I get my upright vacuum steam just now. No I will not my engine will inject ds : Shock: )
User avatar
Moderator
Moderator
Registration: 13/02/07, 22:38
x 839
by Flytox » 21/11/13, 21:16
etienne34 wrote:The problem is that the valve opens only low speed engine. So it shall prevent vapor happen when one climbs in the towers.
Of bagnoles I saw some cut near idle and cut all high speed / high load. But the valve remains open (roughly) half speed.
-injecter outgoing fog with a bubbler kind Econokit in the EGR exchanger instead of LDR. He is then shunted -ci.
You will fall back into the problem of gas that is too hot and that sluts the intake duct. :x
The mist (which is not vapor in the strict sense of the term but liquid water, if I understand correctly) is charged (or simply turns into "real" vapor in contact with the gas and comes out to be injected into the gas. air duct conventionally.
Depending on the construction of your GIllier Pantone and the engine parameters (speed, load, temperature etc ...) you can have "pure" water vapor (rare, possible?), Or a mixture of vapor and droplets of water (frequent), or a mixture of gases (air and or exhaust + steam + water droplets (frequent).
In fact, no one (among amateurs) has yet really characterized the "vapor" which works or works best. It would require laboratory instrumentation ....: Cry: : Mrgreen:
Problem: loss of function of the exchanger cooling since the fog is warm enough (although I do not know the t ° of the LDR qd it returns if ca is it's the same: 40-50 °).
As order of magnitude, the R19, the LDR is 85 °. Econokit the steam outlet temperature is lowest as you say in (40 or 50 °).
You can also replace the EGR valve with a venturi that sucks the vapors from the Econokit. This will increase the flow of steam and warm it while keeping exhaust.
Reason is the madness of the strongest. The reason for the less strong it is madness.
etienne34
I learn econologic
I learn econologic
by etienne34 » 22/11/13, 17:30
It means a compressed hose with a collar that joins the neck of the EGR valve ms instead of this one ?!
I like it.
It remains to acquire the kit. Frankly I have very little confidence in the Econokit. I wonder if the reactor is up. But it is true that the alternative to ecopra 750 AC cools the steam :?
User avatar
Moderator
Moderator
x 839
by Flytox » 22/11/13, 22:32
etienne34 wrote:It means a hose Compressed by a collar that joins the elbow of the valve EGR ms instead of this one ?!
I like it.
Be careful, it's very hot (donf> 500 °) ..... You can leave the valve but blocked in the open position, leave the exchanger in its place, and install the venturi just after.
The bubbler you can do it yourself, you have much more control and flexibility you can optimize its size and location.
etienne34
I learn econologic
I learn econologic
by etienne34 » 26/11/13, 14:14
I believe you have installed on your vehicle doping, flytox. This is a kit or a craft?
If I make myself a bubbler, I can not really make a reactor. But other than simply ecopra has 300 balls spare part, I find not.
Now connect the Gilier to the output of the exchanger,: hard and it makes not cleaning that I will wish for this valve. Finally, there's no quick fix, it'll have to find a way to disassemble.
User avatar
Capt_Maloche
Moderator
Moderator
Registration: 29/07/06, 11:14
x 42
by Capt_Maloche » 23/09/15, 16:05
UP!
With Volkswagen trial in the United States 8)
"Consumption is similar to a search consolation, a way to fill a growing existential void. With, the key, a lot of frustration and a little guilt, increasing the environmental awareness." (Gérard Mermet)
OUCH, OUILLE, OUCH, AAHH! ^ _ ^
  • Similar topics
    Replies
    views
    Last message
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 113 guests
