Hello Gegeyx
Actually it has to bring more realistic value, I do not think it's mockery, on the forum I always respect those who have the courage to do these montages in addition that it is in the semi-illegal in your country, although to make such assembly or to roll with the oil of potato risk here to make us pass for one ( special or off-track), and since we are a very small minority, there is no wizard hunt. (They are all in the reseve next door)
It happens to me the same thing as him, but in a more modest scale, that is to say that at the beginning little or no economy then it is put to take off, on a continuous journey several hundred km this is where I made the 28%, then small runs and average it is degraded, is after a winter stop the first big exit it is returned to 25%, then to
walk to 10% and 20% depending on whether I make short trips or longer, if it's just the city it's not measurable.
Now these numbers 16 may stick a little more to reality and I consider them good in his case, to exceed the 30%.
What must be understood are those who announce (not always badly intentioned) some performance on auto if the figures are very rounded up or done with short distances, so large margin of error, it distorts the values of other editor of panton and sow doubt on those who works to improve ..
50% possible economy or not
Anyway christophe warned everyone, do not expect to do better than 20 even 25%.
Those who have these numbers (André, zac, or kevin?) Are really experts!
But if we want to drill this wall, should it as recommended Pantone or bob_isat (acidify the bubbler): send a little exhaust in the bubbler?
The number of molecules in a drop of water is equal to the number of drop that contains the Black Sea!
lau wrote:Anyway christophe warned everyone, do not expect to do better than 20 even 25%.
hi lau
You know I think I know a little pantone.
15 / 100 I reach it often, 20 to 30 / 100 it is rare on cars or vans and always on vehicles of old generations often under motorized. 2 only time where I exceeded these figures it was on groups (35 and110kwa) used in overload, there I was between 50 and 60 / 100.
But on a small car hdi doing small runs I scratch that slab conso (max 5 / 100), which is the uncertainty of measurement, but I depole
it does not matter for me to ride a pantone it is necessary that the guy joins the assoce, so if it adheres it is provided (at cost price) oil recycle ready for use. So pantone + filtered fryer oil = econology cqfd
Said the zebra, freeman (endangered breed)
This is not because I am con I try not to do smart things.
Hello Lau
Very easy to put a bit of battery acid in the bubbler, or in the carburetor water try is you tell me ...
If you are scared put vinegar in higher doses.
And measure the consomation well.
The differrence is played with the load of the engine, that's why I'm looking for a differrentiel with a bigger report.
The path is not mountainous enough at home, I have to make an 250 km to find small hills.
on the side the yield is much better and on the descent the counter turns but not the consomation,
The experts are 50% we are perseverants
- Similar topics
- Replies
- views
- Last message
- 29 Replies
- 29000 views
Last message by Christophe
View the latest post
04/10/17, 20:17A subject posted in the forum : Water injection in heat engines: information and explanations
- 1 Replies
- 19894 views
Last message by alaniesse
25/03/11, 15:53A subject posted in the forum : Water injection in heat engines: information and explanations
- 15 Replies
- 36027 views
Last message by denis
06/05/06, 00:36A subject posted in the forum : Water injection in heat engines: information and explanations
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 155 guests
