Bondjou,
Problem: regularly, my sewage drain my kitchen is clogging ... too stingy with soap? I send too little hot water? Poorly made pipe? Do not know ..
My ex-wife told me "ho! But me, I used" unblocker every 3 weeks, to maintain the pipes "
So, as for now, I'm warming myself in the wood, I wondered if ... put filtered ash in my sink, from time to time .... it's soda? is a little greener than the déboucheurs of the super market ...
Before doing so, I'm waiting for an opinion ....
Alain
Ash to unclog the pipes?
- Registration: 12/01/07, 08:18
- x 4
- Éconologue good!
- Registration: 08/01/07, 11:43
I was doing something for the kitchen sink that never got clogged when I got an apartment.
I drank coffee made with ground coffee and water (I say because there is so much different way of making coffee already). Well, I just poured the contents of the filter after the coffee, into the sink. Thanks to that, I never got them clogged. This technique was confirmed to me by a girlfriend of the time ...
It's simple, at no extra cost ... however, I do not know if the water company likes this ... note with all the junk that pass in the kitchen pipes ... It can not be negative .
- x 4
ThierrySan wrote:I was doing something for the kitchen sink that never got clogged when I got an apartment.
Yes, yes, a lot of times the "grandmothers" used this stuff ...
But I have a doubt, for the degreasing of pipes ... I was told also, that this system removes bad odors ...
Anyway, coffee waste is 100% bio..finally, almost
- Éconologue good!
Good evening, I know it has nothing to do with the ashes, but here's what I found http://www.youtube.com/watch?v=Sb8oc7wpDb0
I saw it in demonstration at an exhibition near my home, this system seems innovative
- chatelot16
- Registration: 11/11/07, 17:33
- x 264
the true deboucheur is caustic soda, which eats the skin and is very dangerous ... caustic potash will have the same effect
but the ash is only ordinary potash: for the chemist carbonate of potassium
the teaching has turned the paddle by changing the vocabulary: in 1900 potash meant potassium carbonate, and it was necessary to say potash caustic to say potassium hydroxide
I do not know exactly in which year the chemistry teaching has changed: now potash means potassium hydroxide ... the teaching has changed, but it has not rewritten all the books, nor even changed them. commercial name
conclusion we do not finish to see confusion
changing vocabulary is dangerous ... worse if there has been a change of vocabulary we will have to teach the school the date and justification of this change to be able to understand and beware ...
conclusion the word potash or soda alone no longer mean anything
and the potash not caustic of the ash does not debouch ... I would even say that the ash contains also lime and dust mineral of any kind rather of the kind to butcher even more
the coffee grounds is something else: it really cleans even if I do not understand why
but beware the coffee grounds maintain the pipe to prevent it from clogging, but does not make a miracle to unblock ... unlike the caustic soda that managed to dissolve some plugging
what is bad is that if the caustic soda does not succeed to lead, it is dangerous for the one who must dismount the pipes to solve the problem
I say that caustic soda is good to debouch when it goes a little slowly: especially not when it's completely clogged
Yep ..... and we get it back, how does the rag / tea towel ..... before it goes itself plugging the collector and other "Y" a little further?
AMHA a rag is not at all representative of a "clogged" pipe which always allows a minimum of water to pass ..... there will therefore not be at all the same rise in pressure which makes the plug advance like a piston. If you don't have access to the exit to collect the rag, it looks more like a machine to increase problems more than to solve them
Reason is the madness of the strongest. The reason for the less strong it is madness.
- chatelot16
- x 264
the rag is for the demo ... do not voluntarily put a cloth to clean the pipes!
the problem is that if it is well plugged and we have 4 bar has its tap, pvc pipes will not resist ... it will explode or take off somewhere: it would be more prudent to put a reducer Pressure: 0,5 bar would seem sufficient
- Similar topics
- Replies
- views
- Last message
- 15 Replies
- 23519 views
Last message by igoréco
View the latest post
22/01/10, 00:27A subject posted in the forum : Sustainable consumption: responsible consumption, diet tips
- 81 Replies
- 143829 views
Last message by chatelot16
17/03/13, 19:42A subject posted in the forum : Sustainable consumption: responsible consumption, diet tips
Back to "Sustainable consumption: responsible consumption, diet tips and tricks"
Who is online ?
Users browsing this forum : No registered users and 104 guests
