Which does not prevent you from finding something easier than getting stuck in the buckets ...
I think nevertheless that the ram pump would have done the trick
Meow
river pump, simple solutions?
manual pumps
good evening, here's an interesting thing, no need to bother the buckets, but still have to work with the arms http://www.youtube.com/watch?v=oQ6urYtU ... re=channel
sorry it's chinese, short made in china which will eventually arrive with us it seems not bad as an idea
the pipe with the funnel is also good if the garden is lower than the water catchment point, as we say it was simple, but you had to think about it, at least for now you have assembled rigid pipes plastic with scotch tape but later a garden hose with the funnel would last longer
peristaltic pump
Hello, here is someone on youtube who found a funny idea
http://www.youtube.com/watch?v=JyK7CtO8MC0
http://www.youtube.com/watch?v=JI4oX2wZCHY
http://www.youtube.com/watch?v=7j6hrn-3Ir4
http://www.youtube.com/watch?v=sFg7VWk5oZ4
but hey it seems to work this pump, the video is not mine, I found them on youtube
river pump
Good evening, in fact I had the same idea for the piston or diaphragm pump, moreover the peristaltic pumps are generally used in the medical field or in laboratory, there is also the spiral pump, I opened a subject special for that
https://www.econologie.com/forums/sling-pump ... t9601.html
marieagnes wrote:: P hello!
yes i found my happiness but not here ..... rather in my softened brain ....
I picked up all the bits of pipe that were lying around, I taped them to each other (yes yes with big brown tape) and I put a funnel on the end. then with my legs, I climbed upstream and I wedged my pipe between two large stones.
suddenly in my garden I have a hose that is constantly flowing. when I don't need water I put the hose back in the river and when I want I use it to water!
a system that has the merit of being completely free!
couack couack!
Good evening, here is what I found that can replace the funnel
http://www.usinenouvelle.com/expo/bache ... 60978.html
http://www.usinenouvelle.com/expo/bache ... 60977.html
this tarp is used to evacuate the water which leaks from the ceiling towards the outside of a building using a garden hose, an alternative to the bucket, but it can also be used to collect the water of a stream and wedging it with large stones, the firefighters use a large flexible cone in this principle, to collect water by gravity towards their tanks or tank trucks
this solution is really useful when the stream is shallow for pumping water
- Similar topics
- Replies
- views
- Last message
- 6 Replies
- 7350 views
Last message by Ahmed
View the latest post
14/08/22, 21:16A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 29 Replies
- 17468 views
Last message by oli 80
13/06/21, 11:11A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 35 Replies
- 27922 views
Last message by Grelinette
02/08/20, 15:40A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 24 Replies
- 38541 views
Last message by Christophe
26/10/21, 09:36A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 1 Replies
- 8029 views
Last message by Juju64
25/04/20, 17:11A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
Who is online ?
Users browsing this forum : No registered users and 158 guests
