Disappointment "spad"
Edits and changes to engines, experiences, findings and ideas.
User avatar
rezut
I understand econologic
Registration: 01/12/04, 14:58
by rezut » 16/05/06, 12:37
hi asgard os tyr
Besides, I'm still waiting for one on the power bench !!!
I'm up for a test but where?? (because location everywhere is a bit vague) and under what conditions?
a+
ps: following your request I had already posted on the iron or stainless steel post but had no response
rezut wrote:
the worst is that but trying to test the prototypes of others we failed
hello asgard os tyr
I'm going for a test bench but you are on the map or because everywhere it's a bit vague and must not forget that my titin 260000 terminals and I try to spare it because of risk of failure (hydraulic or clutch) (original))
especially since I just put a venturi and now I have a conso of water of more than one liter 100 (too little be)
I'm waiting for your answer and if you're not too far from my house (around chalon sur saone) I'm in (unless the conditions are abusive or too high for me)
a+
Other
Pantone engine Researcher
Registration: 17/03/05, 02:35
x 12
by Other » 16/05/06, 15:46
Hello Rezut
Before going on a bench you have to be sure to make substantial savings, by simple measurement on the main road.
On the bench you will be able to know at what speed and in what condition the reactor works and in what condition it does not hang.
If you just go to the bench to confirm, or you have doubts whether your savings come from elsewhere, you're wasting your time.
Unless you have the bench on hand and use it regularly with each modification, that's interesting.. Because spending an hour on the bench, without being well prepared, you won't have time to learn big thing..
In this case only those who pantonize generators have
the ideal tool for testing. (the voltage and the amperage is a good indication)
User avatar
rezut
by rezut » 17/05/06, 13:42
hello andré
I agree with you but given the short trips I make it's not easy to get good figures and given the price of fuel I'm not going to do 200 or 500 km on the highway just to be sure of my consumption
if I try the test it would rather be to see if I have a real power gain because as zac says the power gain comes with your operating time and it is difficult to realize the gain
and at the same time if possible see the pollution test (with and without pantone)
a+
Back to "Water injection in the engines: the assembly and experimentation"
Who is online ?
Users browsing this forum : No registered users and 209 guests
