greetings,
I made some corrections regarding my invention (already posted here).
it's more about the philosophy of operation, it's useful to understand the thing.
here is the link to the corrected article;
http://www.facebook.com/note.php?saved& ... 8755855531
thanks.
Correction; endless energy engine.
- Obamot
- Registration: 22/08/09, 22:38
- x 5538
Didn't you understand Alain G?
Its goal is:
https://www.econologie.com/forums/post233248.html#233248
"The invention" it's just for the buzz. because:
Its goal is:
snapshoot wrote:mon exposed me read and [...] me doing know
snapshoot wrote:it is useful to understand the thing.
- Registration: 28/09/09, 17:35
- x 554
Re: correction; inexhaustible energy motor.
snapshoot wrote:greetings,
thanks.
well i will not go.
- Moderator
- x 11042
let's talk a bit about the subject, before closing it.
PS1; on digital simulation (or computerized mathematical model), I am not an expert on these "mechanical" oriented softwares, since I was originally trained as an electronics engineer, so it's Mplab, Eagle and Pspice are my specialty, but I However, I'm not a moron on the mechanical-oriented simulation side, I have masturbated my brain enough with Solidworks, I master it well enough, enough to model objects, put them in more or less real contions, and run calculations (simulations ) with the most diverse parameters (to sweep all the possibilities).
but if you prefer, we will do it the old way; in pencil, without any calculation software!
therefore?
PS2; my nickname is snapshoot, "snap" and "shoot" .... its translation is "instantaneous shoot".
therefore?
- Obamot
- x 5538
Since you say to be "originally trained electronics engineer", Very simple question:
- how do you replace an ordinary 1,5 Volt “type A” battery at 2500 mAh:
... by a capacitor? (As is found in many internal circuits of electronic devices - of the type battery eliminator - to keep the preferences stored in memory during battery replacement).
What you are asked:
- what must be done so that your condo discharges in the same way as a battery? And to calculate us the suitable element, so that there is no difference from a standard stack?
- what is the exact type of condo exactly suited to this use and obviously its required value and performance?
- note: the capacity of the condo must be equivalent to or greater than the capacity of a standard battery as described above.
You see, this is a simple question for an electronics engineer, who is also a "researcher".
Any attempt not to respond will demonstrate that you are dodging because you do not have the skills that you claim. And you have an interest in responding very quickly!
What you are asked:
the discharge of a codo through a resistor is not a "linear" curve, we will have (over time) a decrease in the voltage and current at the terminals of our load.
but this rate of "sagging" of the quantities (i and v) depends on two main parameters; the capacity of the condo, and the resistance of the load.
so, theoretically, we can replace a battery (of a certain type) with a condo ..... but it is very conditioned as we have already seen.
I made you there a descriptive "study" of the thing, like that, on the fly, if you want a mathematical demonstration (with blows formulas enriched in derivative and integrals) I must go back to my lessons of ten ago years ...... you want some?
so give me a little time to revise all that and I come back.
to +.
PS:
I'm afraid we're going to move away from my subject there.
to +.
PS:
Go back to "Innovations, inventions, patents and ideas for sustainable development"
Who is online ?
Users browsing this forum : No registered users and 170 guests
