Hello,
Please note, these are not wind turbines !!!
http://news.discovery.com/tech/wind-power-without-the-blades.html
To see
A new type of wind machine!
Use reed or bamboo type rods full of piezoelectric converters shaken by the wind, has a low efficiency, on which these links are silent, because the energy of the wind is recovered by its push or force on surfaces, which give a power proportional to the speed of movement of this surface.
The optimal speed at maximum power is one third of the wind speed.
So these bamboos have no large surface against the wind, therefore low force, and do not move quickly, attached to their base, far away from the wind speed, therefore low yield.
Modern wind turbines verify these two principles, with amplification by the typical lift of an airplane wing.
So many variants of bamboo or leaves stirred in the wind will have a low yield per m2.
Except extreme simplicity, not expensive, (not the case here) they have no interest.
- Obamot
- Registration: 22/08/09, 22:38
- x 5538
Well...
Yes Alain G, I do not understand either how we can zap so easily on the calculation of the lever arm!
If we only recovered 30% of the force of the wind, it would be difficult to move the sailboats forward ... (Everyone will have noticed, moreover, that the higher you climb on a mast, the more the sails are surface reduced ... Otherwise everything would explode: CQFD ...)
Not to mention the other "Forces", I really don't understand how it is that someone who claims to be a "physicist" also quickly neglects the basic rules of his discipline, such as mass law or the very important moment "Force (x) Lever arm", that the wind applies - as much on the sails of a boat - as on these very long artificial rods, with calculated flexibility ... (180 feet = 54 meters high anyway ...).
and a "Gentle breeze" of about 15 km / h (force 3 on the Beaufort scale) and deploying a force of about 1 kg / m2 on sails, would be found to be instantly multiplied by 50 times the initial force! (And just a little less in a phase of "release"In the case of these artificial bamboos ... difficult to calculate but absolutely not to neglect since we are then in the presence of inertial forces which will in turn find themselves amplified by the thrust of the wind ... but let's just stay on the calculation of the moment ... for simplicity!)
Therefore, even if it was not possible to recover "only" 30% of the initial "Force": this would be multiplied by the length and there would still be a usable force of 15 kg / m2.
A "Fresh wind"According to Beaufort and it will be 150 kg / m2, a"Great fresh»Not far from double (300 kg / m2) and for"Gusts of wind", up to 550 kg / m2 !!!
PS: I apologize to the community of Forum not to laugh at me with clever mathematical formulas that are incomprehensible to the forumtheir means, and if re-establishing the truth is considered here as "goad»Those who overestimate their own assessment (if I remain polite ...). And with those who take the opportunity to settle their accounts ...
Obamot Hi!
My answer tried to demonstrate the negativity of Dede!
To return to the original subject, we can compare this type of recovery to a magnet in front of a coil, if we move the rod it will produce energy but if on the other hand we stretch it on one side it will not produce, so for that it works well the wind must come by bourasque.
In the end it can very well be installed where there are squalls, where the conventional wind turbine does not perform!
Finally there is still something that escaped Dede I know everything that jumped on the subject again negatively!
Stepping behind sometimes can strengthen friendship.
Criticism is good if added to some compliments.
Alain
Alain
- Similar topics
- Replies
- views
- Last message
- 13 Replies
- 11377 views
Last message by phil59
View the latest post
20/06/22, 16:31A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 22 Replies
- 36540 views
Last message by oli 80
28/05/17, 00:02A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 0 Replies
- 4046 views
Last message by Jboul
30/01/14, 18:25A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 4 Replies
- 5359 views
Last message by raymon
13/03/13, 20:35A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 0 Replies
- 3575 views
Last message by tigrou_838
23/02/09, 15:05A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
Back to "hydraulic, wind, geothermal, marine energy, biogas ..."
Who is online ?
Users browsing this forum : No registered users and 287 guests
