Thank you I received your email and the doc. So I will come to Bourbon in July and I hope that your wind turbine will bring satisfaction on all levels.
Good day to you .... under the greyness here yuck ... and without wind ;-)))
New type of wind turbine with Magnus effect?
- Pear Belle Helene
- Éconologue good!
- Registration: 16/05/07, 09:21
- x 1
- Pear Belle Helene
- Éconologue good!
- x 1
If you like the Magnus effect wind turbine, see the Magéole.
It is done by Auvergnats de Polytech 'Clermont (formerly CUST: university center of science and technology)
it works, that's for sure. By cons, in performance, I do not know if it's top compared to a three-bladed.
Remundo wrote:If you like the Magnus effect wind turbine, see the Magéole.
Hello,
Unable to find performance info!
Just an indication in the summary:
http://cat.inist.fr/?aModele=afficheN&cpsidt=9251295
Obelix
In medio stat virtus !!
Hi Obelix,
Thank you for the link,
"theoretically" ... for sure.
The blades must rotate very quickly to obtain a significant Magnus force. This requires complex machinery.
Moreover, gyroscopic effects will appear, and I have not seen this written anywhere. You don't spin a moving axis "like that" at high speed.
that is to say that the blades turn so quickly on themselves they oppose by "inertia" to the change of position of their own axis of rotation (gyroscopic effect).
it's explained there for motorcycle wheels
http://www.mecamotors.com/e_theorie/01_ ... gyro1.html
The gyroscopic couple opposes the force of the wind which induces the rotation of the wind turbine, just as it opposes the leaning of the motorcycle when the rider is turning: it is even a stabilizing effect sought for the motorcycle when cornering.
For a wind turbine, a couple that opposes the rotation driven by the wind ...
So there is probably a compromise to be found between the speed of rotation (gyroscopic brake) and the Magnus effect (wind accelerator) obtained
I prefer the ROBIPLAN
Hello,
For the gyroscopic effect I still found an order of magnitude => 3000 RPM.
On the other hand I did not find a machine with three "blades" that of the bi-blades which must quite shake the axis of rotation of the whole because of the precession!
Even found a Magnus with vertical axis and vertical tubes with change of direction of rotation of the tubes at 90 ° from the wind!
Obelix
Obelix
An efficient and robust Magnus wind turbine seems technically difficult to achieve.
Finally, I'm just waiting to see.
By the way Obélix,
Remundix published 2 or XNUMX odds and ends on ROBIPLAN and following pages from our National Pascal.
Had you seen?
By the way Obélix,
Had you seen?
- Similar topics
- Replies
- views
- Last message
- 13 Replies
- 11810 views
Last message by phil59
View the latest post
20/06/22, 16:31A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 22 Replies
- 36885 views
Last message by oli 80
28/05/17, 00:02A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 0 Replies
- 4104 views
Last message by Jboul
30/01/14, 18:25A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 4 Replies
- 5402 views
Last message by raymon
13/03/13, 20:35A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
- 5 Replies
- 6041 views
Last message by Alain G
19/06/12, 17:02A subject posted in the forum : Hydraulic, wind, geothermal, marine energy, biogas ...
Back to "hydraulic, wind, geothermal, marine energy, biogas ..."
Who is online ?
Users browsing this forum : No registered users and 296 guests
