I understand that the mttp requires a steady rise in voltage, that it can stall. because once in injection the voltage drops and the injected watt increases.
If we stall everything at the start it's 37v direct, it refuses.
The 12v is obtained with a small rotating drill.
The strange thing is the effect of thrust on the axis it goes in 1 cm if you push and comes back to its place like a pneumatic shock absorber
The resistance to the drill is very low as soon as it occurs. maybe more towards 150w but the drill at 15 € of 10 years from leclerc which should have died 50 times already: I don't blame him
She hurts seriously at the end.
I upload and edit the video. sacred phone it's HD it's long on youtube.
Comparative observation Air X, breeze, Rutland and Aerogen
- plasmanu
- Registration: 21/11/04, 06:05
- x 180
The rise in injected watt is very slow.
I hook up the GTI, at 11v, it holds me back a little and then I accelerate (but not too much otherwise I have passed the critical threshold of 27 and it's blackout) a little strong not too much, find myself at 23v 130w and I wait, at equal power on the drill with the locking of the adjustable notch +/-
it ends 2 minutes later in 15v 175w, as the voltage drops the watt goes up.
"Not to see Evil, not to hear Evil, not to speak Evil" 3 little monkeys Mizaru
- plasmanu
- x 180
http://youtu.be/8VwKRw9VeWY
After I took out the heavy artillery but it gives that 10V is much too slow even if it is full of horses
- plasmanu
- x 180
2Gti solar + hybrid in parallel.
It worked the first time
Direct 14v and 100w to the wattmeter.
Both flash green.
A voltage boost over 27v
After systematically the solar in island mode (red led) nothing more to draw from it it refuses.
Only the hybrid accepts
Putting back the solar on these 2 panels. And roll my hen he starts again.
Not hang around. Because the day is up and I had not put the panels to the mass nor covered with a tarpaulin either.
Both flash green.
Back to "hydraulic, wind, geothermal, marine energy, biogas ..."
Who is online ?
Users browsing this forum : No registered users and 293 guests
