Hello
In the stem tests I try what I have on hand without more.
Look for materials with a specific purpose.
the magnetic permeability side or I would say rather magnetic ferro is not a criterion of function.
On the other hand the thermal side has an infuence and probably the metal also example the copper and the aluminum thermal conductivity similar.
No one has yet to explain why it takes a certain temperature to run the reactor and that the operation is not proportional to the temperature of the reactor.
that is, a reactor has 550c running and a 700c does not necessarily work better proportionately. Nobody tries to heat a reactor to red, (I'm just heating the exhaust jacket with the torch outside to red, and I have seen nothing of lightning) It is true that to make a good test it would be necessary to make a reactor
with an auxiliary heater.
do all these tests is a full time job!
Iron or stainless steel for pantone reactor?
- Philippe Schutt
- Registration: 25/12/05, 18:03
- x 33
Hello,
With an aluminum bar in a 100% panton there is practically no differrence with an iron bar
so no autollummage running with red fuel oil
Let's say that in the language I will keep the term auto-ignition
Clink (sewing mill noise due to mass burning)
When I talk about autoallummage that's what you hear when you run an engine with poor quality gasoline
or the old essence that has been dragging in a drum for too long.
the engine heats up more, it loses power, it tends to turn without the candle fires.
- Similar topics
- Replies
- views
- Last message
- 0 Replies
- 6477 views
Last message by Christophe
View the latest post
03/03/08, 15:51A subject posted in the forum : Water injection in heat engines: information and explanations
- 74 Replies
- 66419 views
15/12/07, 08:31A subject posted in the forum : Water injection in heat engines: information and explanations
- 8 Replies
- 8872 views
Last message by Other
27/01/06, 03:29A subject posted in the forum : Water injection in heat engines: information and explanations
- 42 Replies
- 88053 views
16/10/10, 00:31A subject posted in the forum : Water injection in heat engines: information and explanations
- 2 Replies
- 6656 views
11/11/04, 23:27A subject posted in the forum : Water injection in heat engines: information and explanations
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 123 guests
